E8400 wolfdale users.
fbm211
fbm211 Posts: 1,488
edited August 2010 in The Clubhouse
Whats your temps.
Im getting readings at 44c-(core0) and (49c-core1.)
This is with a zlaman copper heatsink.CNPS9800 I think.
Are these temps safe?
My PC isnt 100% stable....games just quit.IE locks up
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2010
    Had an E8400 2 years ago, ran I think it was...39-41c and up to 45-49c full load using a Thermaltake heatsink. I remember that much cause I never saw past 51-53c. It was my gaming computer.
    Did you OC yours at all?
    I OC'd mine, upped the voltage as well as changed the timing on my memory and OC'd my video cards.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    Those are my idle temps
  • concealer404
    concealer404 Posts: 7,440
    edited August 2010
    What paste did you use when you installed the Zalman, and how much of it?
    FWIW, i've never been a fan of those Zalman heatsinks, but i don't think it should be the problem, here. Sounds like the install may have been botched.
  • kawizx9r
    edited August 2010
    fbm211 wrote: »
    Ouch, bet you already know this but keep in mind regardless of how many fans you've got in your PC...it's taking air from within the room you're in so that could be a factor as well to consider. I had a small AC in the room I was in.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    edited August 2010
    Good point Ben!
    Btw, 6k posts? God damn :eek:
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    I have AC.
    I think concealer404 is on the right track.
    I used zalman paste.Just a bit on the sink and a bit on the cpu like always.Never had this problem before.
    Its time to order some more artic sliver 5 like I always used before.I need a new mouse anyway.
  • concealer404
    edited August 2010
    kawizx9r wrote: »
    Good point Ben!
    I HAVE been here for twice as long as you, you know. ;)
    I've been slowing down a bit, though. I'm at a wierd crossroads where i have no idea where to go with my rig. It's partially your fault for taking "my" Paradigms. :p
    I'll pick back up when Chris brings me teh new hawtness. :D
  • kawizx9r
    edited August 2010
    Lol true, that and I had that sudden 'absence' from the forum.
    Hey, I always told ya the Paradigms are simply waiting in my rig until you've got a chance to take them! I plan on returning back to Magnepan speakers anyway so whenever you can swing it let me know! Got the original boxes and everything.
    And good call FBM, I've never used Zalman or any other paste for that matter other than the Artic stuff.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • concealer404
    edited August 2010
    fbm211 wrote: »
    I have AC.
    When you say "a bit," how much do you mean?
    Is the zalman stuff copper, silicone, or silver based? Silicone paste is a waste of time, and i don't like the copper, either.
    Order some AS5, make very sure you get both the heatsink and the cores squeeky clean before you install again. Then, on the CORES ONLY, put a small bit of AS5, think like... small grain of rice. Then install heatsink.
    I always did a "no-no" and would spread the paste evenly with a credit card over the heatsink with great results in performance, but common wisdom says NOT to do that, so i'd stick with that.
    That said, i DID manage to get my old AMD Athlons to idle at dead room temp using that method back when i was into overclocking. (Yes, still on air cooling.)
  • concealer404
    edited August 2010
    kawizx9r wrote: »
    Oh, i'll be taking them, then. ;)
    I still need to call you, (and chris for that matter) just been stupid busy. Lots of news and stuff. :)
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited August 2010
    Those temps aren't too high. I have a E8400 running at 3.8Ghz, temps are 43c and 39c at idle, but I've seen them both go to 50c when encoding, I use an aftermarket heatsink, forget the manufacturer. Computer has never crashed in two years.
    I've seen E8400's with stock heatsinks at work run 50c all day long without an issue. Looks like a software issue to me, or maybe a buggy motherboard.
  • kawizx9r
    edited August 2010
    Yeah same, currently in Texas...and that PT Cruiser GT is an automatic. The turbo in it makes the car fun. Tell you all about it later.
    FBM, what kind of mouse are you getting? Got me missing my older E8400. Was running Corsair XMS2 ram with dual 8800 GTS SLi'd.
    Dual boot, XP as my main and Ubuntu as my alt but I'd run both anyway (Ubuntu on virtual machine) with dual monitors. Now I run an AMD with a 5750 also on dual monitors (Vista and Fedora mainly but sometimes Ubuntu) on my main computer.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • concealer404
    edited August 2010
    Ah... i didn't know what the temps of those things were supposed to be. Just sounded way high from what i'm used to.
    Might be time to run some memory tests.
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    I have some AS5 but its over 2 years old and has been used twice.---Too old.
    The zalman stuff is white and I would have to say that after this I will never use anything but AS5 again.Maybe Ill get some of that AS cleaner too.
    This rebuild went perfect except for the thermal problem.And I need a CPU power cable extension.
  • concealer404
    edited August 2010
    Does AS5 have a shelf life? I still have some from like... 5 years ago that i used a couple weeks ago on a laptop that was overheating.
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    I think Ill get a RAZER diomondback or Copperhead.:D And mouse pad too.
    Im going to reinstall XP again..Dont want to blow too much money as I plan to go to an i7 platform in a few months.Ill set up a dual boot with XP for gaming my current games and win 7 for internet and the games coming out soon.---Like Need for speed coming out in november.:D
    I read on newegg somewhere to use fresh thermal paste.Its probably still good though.Ill have to look in the old parts box for it.
  • kawizx9r
    edited August 2010
    fbm211 wrote: »
    Make sure to look into the model you plan to get, I heard some of them can run a bit warm and they're of mediocre build quality. I've always stuck with Logitech :)
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • concealer404
    edited August 2010
    I <3 Razer mice.
  • WilliamM2
    edited August 2010
    I don't think so. I still have some AS3 I've been using for at least 8 years, works as well as it ever did.
  • polktiger
    polktiger Posts: 556
    edited August 2010
    running a Xigmatek 1283 I was getting idle temps around 30 degrees and full load video encoding at 55 or so. I changed some things up and am now using a little Rosewill Z300 cooler (basically a simple stock replacement, using the Xigmatek in a different machine), and it is idle around 35 degrees. No overclock.
  • Bobsama
    Bobsama Posts: 526
    edited August 2010
    Pentium E6300 (Wolfdale) @ 3.5GHz (turned down for the summer)
    47-49C at 100% load with ~27C ambient.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
    billbillw Posts: 7,550
    edited August 2010
    Your temps are fine.
    At stock speeds, Intel Core CPUs are happy as long as you keep them under 70C. The actual spec that Intel gives is 72.4C, but I'd be a little worried at anything above 65C though.
    My Q9550 with a older Zalman flower type cooler and Arctic Silver generally runs around 44-48C at idle on core 1 (environment is usually around 25C). I see 55-58C under heavy encoding loads. The other cores tend to run a few degrees cooler. I've had absolutely no stability issues.
    BTW, I wouldn't worry about your AS5 being too old. The stuff is basically very fine silver particles emulsified in an oil paste. How does that go bad? You should make sure you followed the most current Arctic Silver directions for your CPU. They vary a lot depending on the core arrangement, etc.
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    The fans I ordered for the top of the case got here today and the DEMCiflex Computer Air Filters will be here next week.
    Best of all I got a 4c temp drop.49 down to 45.:D
  • kawizx9r
    edited August 2010
    Niiice.
    I'd like to hear about your CPU once you reapply the thermal paste between it and the heatsink.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    The AS5 should be here monday.
    Id like to OC it.Ive been getting my read on P35-DS4 OCing and a-lot of people get this set-up to 4GHZ----Easy.
  • renowilliams
    renowilliams Posts: 920
    edited August 2010
    fbm211 wrote: »
    This is a link to the heat sink and fan I use. You can get it now and use it. When you buy your i7 you'll be able to use it with it,as it comes with mounting hardware fot LGA775, socket 1156 and socket 1366 cpus. It also comes with mounting hardware for AMD sockets as well.
    http://www.overclockersclub.com/reviews/noctua_nhd14/
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • Fongolio
    Fongolio Posts: 3,516
    edited August 2010
    I have an 8400 running at just under 4 GHz using a Corsair H50 liquid cooling setup. My idle temps are very close to yours but even under load I rarely see variations of more than 5 degrees. Also rock solid. No crashes. Ever. Here's a link:
    http://www.corsair.com/products/h50/default.aspx
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    Would DDR 2 memory run on DDR3 mobo.For instance this one.>> http://www.newegg.com/Product/Product.aspx?Item=N82E16813128422.
  • renowilliams
    edited August 2010
    fbm211 wrote: »
    No, DDR2 memory will not work on that board.
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
  • Bobsama
    Bobsama Posts: 526
    edited August 2010
    DDR2 memory is NOT pin-compatible. While both have 240 pins, there's a notch that simply won't fit in the wrong type of slot.
    Another option for you might be going the AMD route. If you've already got 240-pin DDR2 667+ DIMMs (ie: desktop RAM, not 200-pin laptop RAM), you can get away with saving $50+ (for me, more like $120-150) by going with an AMD AM2+ motherboard that uses DDR2.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813186149 or http://www.newegg.com/Product/Product.aspx?Item=N82E16813130266
    And, for a processor, http://www.newegg.com/Product/Product.aspx?Item=N82E16819103809 or http://www.newegg.com/Product/Product.aspx?Item=N82E16819103851
    You'll also want to make sure that your power supply is good enough for the load. A $20 unit simply won't cut it long-term. If you're only planning on running stock (not overclocking), then a power supply such as a Corsair 400CX, Seasonic SS-400ET Bronze, or Antec EA-380D or EA-430D would be great choices.
    On a side-note: a Wolfdale processor WILL NOT WORK in an LGA-1366, LGA-1156, or AM2/AM2+/AM3 motherboard. They'll only work in LGA-775 motherboards which have long since been EOL'd (discontinued).
