Which amp????
Halflungshort
Halflungshort Posts: 10
edited August 2010 in Car Subwoofer Talk
Wondering which amp would be better for 2 10" gxr.
Pa330.2 or the pa880.1. Subs are 165rms each @ 4ohms.
Anyone know if these subs are dvc or svc?
Post edited by Halflungshort on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2010
    DVC = they'll have 2 sets of terminals per driver. Do you know what drivers you have exactly? :confused:
    Btw, welcome to Club Polk!
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Halflungshort
    edited August 2010
    Woofer 1 - 10" Diameter (25.40cm)
    Poly/Mica
    Electrical
    Overall Frequency Response 29-400Hz
    Nominal Impedance 4 ohms
    Power Handling (continuous) 165 w
    Power Handling (peak) 365 w
    Efficiency 89 dB
    Voice Coil Diameter: Driver 1-1/2" (3.81cm)
    Install Dimensions
    Full-range Mounting Depth *
    Top Mount 4-1/2" (11.43cm)
    Bottom Mount 5" (12.70cm)
    Cut-out *
    Driver Cut-out Diameter 9-3/16" (23.34cm)
    Thiele/Small Parameters
    Resonant Frequency 34.37 Hz
    Qms 7.0
    Qes 0.53
    Qts 0.49
    Vas 2.31 ft3
    Sd 53.69in2
    Xmax (linear) 0.24
    Le .97 mH
    These are the all the specs. I only see 1 set.
  • chu
    chu Posts: 178
    edited August 2010
    your sub is dvc, 880 has more power in a 2ohm mode. I would go with 880.1
  • Halflungshort
    edited August 2010
    Thanks. Change of plans. Had to buy tires yesterday so the amp is on hold yet again. Going to build a proper size box. This should help my current setup.
    Current setup: 1 10" Polk gxr sub
    Sony explode 222w amp (I know you don't have to say anything about the amp)
    bridged@4ohms
    stock hu
  • chu
    chu Posts: 178
    edited August 2010
    DSkip wrote: »
    You mean SVC
    I googled the gxr specs and it camed up dvc, so who knows.
  • Halflungshort
    edited August 2010
    Hadn't been able to find out either. Guess I'll run it by an audio shop to see
  • Halflungshort
    edited August 2010
    Checked again. Definitly svc. Only one set. Thanks
  • lightman1
    lightman1 Posts: 10,796
    edited August 2010
    A big one with lots of graphics on the cover.
