Which amp????
Halflungshort
Wondering which amp would be better for 2 10" gxr.
Pa330.2 or the pa880.1. Subs are 165rms each @ 4ohms.
Anyone know if these subs are dvc or svc?
Post edited by Halflungshort on
DVC = they'll have 2 sets of terminals per driver. Do you know what drivers you have exactly?
Btw, welcome to Club Polk!
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Woofer 1 - 10" Diameter (25.40cm)
Poly/Mica
Electrical
Overall Frequency Response 29-400Hz
Nominal Impedance 4 ohms
Power Handling (continuous) 165 w
Power Handling (peak) 365 w
Efficiency 89 dB
Voice Coil Diameter: Driver 1-1/2" (3.81cm)
Install Dimensions
Full-range Mounting Depth *
Top Mount 4-1/2" (11.43cm)
Bottom Mount 5" (12.70cm)
Cut-out *
Driver Cut-out Diameter 9-3/16" (23.34cm)
Thiele/Small Parameters
Resonant Frequency 34.37 Hz
Qms 7.0
Qes 0.53
Qts 0.49
Vas 2.31 ft3
Sd 53.69in2
Xmax (linear) 0.24
Le .97 mH
These are the all the specs. I only see 1 set. -
your sub is dvc, 880 has more power in a 2ohm mode. I would go with 880.1
Thanks. Change of plans. Had to buy tires yesterday so the amp is on hold yet again. Going to build a proper size box. This should help my current setup.
Current setup: 1 10" Polk gxr sub
Sony explode 222w amp (I know you don't have to say anything about the amp)
bridged@4ohms
stock hu -
Hadn't been able to find out either. Guess I'll run it by an audio shop to see
Checked again. Definitly svc. Only one set. Thanks
A big one with lots of graphics on the cover.
