Looking for Misc Audio Deals of the Day? Updated info here!
this looks like an awesome deal. no affilliation.. I'd go get them myself, but the wife thinks i have enough speakers currently.
http://austin.craigslist.org/ele/1873220192.htmlMain 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
meant to post this
1 PAIR OF High-Quality Copper Speaker Banana Plugs for $.97
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2801&seq=1&format=2mole' -
meant to post this
Those "close screw" types of bananas are murder to work with. I was using them on my HT speakers (five sets), not those particular ones but the same design, and no matter how much I tightened the things, they would come loose or the wire would just pull out of the plug while watching TV or a movie. They're solidly made but you have to use two pair of pliers to really get them good and tight. Be careful, put a peice of cloth between the contact points of the pliers and the plug and for goodness sakes DO NOT over tight them as they will snap. Even if you are going to use spades, you must get them very tight. -
^^^^ +1
I agree, those are difficult to work with - I had ones similar to that!
James2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player -
I like how it says copper in the title, but in the description: "Ferromanganese Tip" http://en.wikipedia.org/wiki/Ferromanganesemeant to post this
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2801&seq=1&format=2"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Whoa, in that case DO NOT use the pliers as I stated above because the "Ferromanganese" is crap and will brake even under slight pressure from two pairs of pliers. Well maybe not because it says the tip. Why the hell would they use copper on the whole base and nanner clip and put that crap on the end? Perhaps because it is more pliable than copper thus allowing you to spread the springs easier? It can be for good conduction. -
guess i better cancel my order then. i was gonna use them as spares. thanks for the inside infomole'
Two blu-ray movies for $20 and get a $15 gift card back at Best Buy.
http://www.bestbuy.com/site/olspage.jsp?type=category&id=pcmcat216800050024&AID=10597222&PID=552179&SID=TFXajgoBCjYAADTukgsAAANq&URL=http%3A%2F%2Fwww.bestbuy.com%2Fsite%2Folspage.jsp%3Ftype%3Dcategory%26id%3Dpcmcat216800050024&ref=39&loc=01My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Just note: It's limited to a very short list of titles, and you probably can't combine the two offersMay not be valid in combination with other offers____________________
Pool: Atrium 60's/45's -
^^^reported^^^SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
For all you Yamaha folks here is a Blu-ray player at a great price:
http://www.vanns.com/shop/servlet/item/clearance/487962144/yamaha-bd-s2900 -
Conradicles wrote: »For all you Yamaha folks here is a Blu-ray player at a great price:
that looks like a nice BDPmole' -
mole', might as well buy it since you're on such a spending streak!
dane_peterson wrote: »mole', might as well buy it since you're on such a spending streak!
picked up a new Elite BDP-23 to match my new Elite SC-07. so no real need for another BDP now.mole' -
Monitor 70s from newegg for $179
$70 off w/ promo code SPEAKER82A, ends 8/9
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290208&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=2525508&SID=bountii-4231096-08040021mole' -
Denon AVR-990 Multi-Zone 7.1 Channel Home Theater Receiver $659 shipped (NIB)
http://www.jr.com/denon/pe/DNN_AVR990/mole' -
$100 Craigslist Atlanta...some GA bros should snag this.
http://atlanta.craigslist.org/nat/ele/1880864234.html
--Gary--
MOle, you are going to like your BDP-23 mated to your Elite. I have somewhat the same, only my Elite is the 21TXH and PQ/AQ blows me away, so much so, I had to put a seatbelt on my Lazyboy............ -
lessthanzero wrote: »MOle, you are going to like your BDP-23 mated to your Elite. I have somewhat the same, only my Elite is the 21TXH and PQ/AQ blows me away, so much so, I had to put a seatbelt on my Lazyboy............
that is so nice to hear.
it shall be here on Friday.mole' -
If anyone needs a simple PC solution, I imagine this is hard to beat for the price:\
http://www.buy.com/prod/M-Audio-AV40-Studiophile-Speakers--Refurbished/q/loc/111/216988623.html
M-Audio AV40 for 80 bucks shipped.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
http://sfbay.craigslist.org/nby/ele/1881428941.html
For those needing a CS350LS.. The ad says one owner and in excellent shape. -
HUH?? The titles show up as $22.99 each. How does your math end up being only $5 when all is said and one?Two blu-ray movies for $20 and get a $15 gift card back at Best Buy.Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!! -
Clarification - that's what I read from your post...maybe you meant "$20 (ish) each"?HUH?? The titles show up as $22.99 each. How does your math end up being only $5 when all is said and one?Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!! -
Two different offers, one for a $15 GC back, and one is 2 for $20.
See the top of this page.____________________
I did - your link is different than the original link here. But I see your other link does go to the 2fer$20 deal.
However, there in no all-encompassing deal that includes both 2 for $20 and $15 GC back. Your original post was misleading...
If your post instead read "Two blu-ray movies for $20 or get a $15 gift card back at Best Buy", then I wouldn't have questioned it.Two blu-ray movies for $20 and get a $15 gift card back at Best Buy.
Hey, I admit I like a great deal like anyone else, so the prospect of getting two BDs for $5 AR had me ready to buy!
^^ OK, now I see I've quoted two different posters! Guess I'm the one that's a bit confused...sorry!
Ebony LSi9's with stands in great shape in Jersey for $250.
No affil.
http://jerseyshore.craigslist.org/ele/1869620644.html
If I wasn't too busy to pull off the 12 hour round trip I'd be all over these. Somebody needs to get these if they're still available.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
I think that's the best price I've ever seen on a set of 9's. Wish I was closer. -
