LSi9 vs LSi7
cokewithvanilla
cokewithvanilla Posts: 1,777
edited December 2013 in 2 Channel Audio
I was going to buy the 9's for my apartment when I go back to school in a few weeks, but I read a thread that said better things of the 7's than the 9's (not that I believe everything I read, but it surprised me)....
I've heard such great things about the 9's, though I've heard little of the 7's. Anyone have thoughts on this matter?
They will be powered by an adcom gfa-5800, signal cable, a random computer (hopefully digital out, I suppose that will depend on the pre).
Post edited by cokewithvanilla on
  • skipf
    skipf Posts: 694
    edited August 2010
    When I was on a speaker buying trip, I was looking at some Klipsch bookshelves and the salesman showed me a set of LSi7's. They were much better than the Klipsch models I was listening to, and I was ready to jump on them. He then said "before you make up you mind, you need to hear these" and turned on the 9's. The 7's weren't even in the same ballpark. I bought the 9's. Good salesman.
  • Cpyder
    Cpyder Posts: 514
    edited August 2010
    I'm really enjoying my 9s and would recommend them to anyone. Especially for small apartment size/type rooms. They easily fill it and I've been asked several times where my sub was. (I don't have one). I'm don't think the 7s have the same bass response in comparison. There's other differences that I can't recall right now. Google Lsi7 vs Lsi9.
  • markmarc
    markmarc Posts: 2,309
    edited August 2010
    If you've got good, and I mean good amplification, go with the 9's. Then save up to mod the x-overs.
    Former Staff Member TONEAudio
    2 Ch. System
  • madmax
    madmax Posts: 12,434
    edited August 2010
    I liked the 7's much better for music. They had a special quality which my 9's didn't, I think due to the simpler crossover.
    madmax
    Vinyl, the final frontier...
  • cokewithvanilla
    edited August 2010
    Thanks for the replies.
    I listed the amplifier in the first post... I've used it on my 25's and compared it to the the 7270, I think I can tell a subtle difference.
    With that amp and an equivalent pre, which speakers will (should) sound better? Modding the xo's sounds like something I would do in the future.
  • rooftop59
    rooftop59 Posts: 8,120
    edited August 2010
    I have read that the 7s are really a 6 ohm speaker whereas the 9s are a true 4 ohm if that makes a difference. I have not heard the 9s unfortunately, but I LOVE my 7s, best speakers I have ever heard (which of course tells you that I am not the person to ask ;)) I don't know about your amp, but if you are worried about power and have a musical sub, go with the 7s. I wouldn't run the 7s without a sub except in a small office or dorm for background music, if you are going to use them for any gaming/music or just bass heavy music, I think you need a sub. Just my 2 cents.
    Peace,
    Paul
    Game Room 5.1.4:
    Bedroom 2.1
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2010
    Loved my 7's when I had them, they were no Magnepan's but wow did they sound gorgeous!
    Other than proper amplification, I hope you're running a good pre and source...those speakers can be pretty damn detailed.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • cokewithvanilla
    edited August 2010
    Alright, well I guess I should ask this: is the second driver in the LSi9 simply a low range driver? What frequencies does it handle?
    I would be using this in my small apartment for music mostly. I haven't decided on a preamp... something simple with digital, i'd imagine (any thoughts are welcome too)
  • Norm Apter
    Norm Apter Posts: 1,036
    edited August 2010
    anonymouse wrote: »
    I'm sure the 7s are easier to drive than the 9s. But the 9s with modded crossovers and proper amplification are heavenly.
    What he said!
    Listening to an old Grant Green jazz CD on modded 9s now and its like I've got the band in the living room.
    2 Ch.
    Parasound Halo A23 Amp
    Parasound Halo P3 Preamp
    Parasound Halo T3 Tuner
    Bada HD22SE tube CD Player
    Magnum Dynalab Signal Sleuth
    Magnum Dynalab ST-2 antenna
    polkaudio Lsi9s (upgraded cross-overs)
    MIT Shotgun S-3 Bi-wire Interface Speaker Cables
    MIT Shotgun S-3 Interconnects (3)
    IegO L70530 Power cords (3)
    HT
    Denon 2808ci AVR
    polkaudio RTi A5s (fronts)
    polkaudio RTi A1s (rears)
    polkaudio Csi A6 (center)
    Signal Cable Ultra Speaker Cables
    Signal Cable Analog II Interconnects
  • Cpyder
    Cpyder Posts: 514
    edited August 2010
    http://www.polkaudio.com/homeaudio/lsi/specs.php#bookshelf
  • dhart86
    dhart86 Posts: 1,594
    edited August 2010
    I've had both speakers. I preferred the 7's for music and the 9's for HT. I should advise that when I had the 9's I was new to the hobby and didn't experiment with placement before I sold them for the 7's. At the time the 9's sounded muffled or something. I love my modded 7's for music, though
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • philipjr
    philipjr Posts: 45
    edited August 2010
    Cpyder wrote: »
    Second mid runs 200hz and down. Other mid runs full-range. Nines are better in a room where you can pull them well away from walls and sit at least several feet back for listening position. They do put out a surprising amount of bass for their size, which makes placement more critical than with some speakers since you may have issues with reflections due to the ports being in the back...
    That being said, the Nines are a much more full-sounding speaker than the Sevens, and can handle a lot more power. I have not heard that the Sevens are 6ohm - nominal is listed as 4ohm just like the Nines. The nines can even dip below that at some points, and with their hefty power requirements you definitely will want a beefy amp. No receiver I have ever seen will really cut it, 4ohm stable or not. I am running 185wrms per channel to them and most folks on here would tell you that is not even enough to get the best performance out of them...
    Hope this helps. Either way, nice speakers.
    Polk LSi-9s and Micropro 2000 sub
    Asus Xonar Essence ST 24-bit soundcard ASIO
    Kimber PBJ interconnects
    Emotiva USP-1 analog preamp
    Emotiva UPA-1 monoblocks
    JRiver media player (upsampling to 24/192)
  • philipjr
    philipjr Posts: 45
    edited August 2010
    dhart86 wrote: »
    I thought the same thing when I first got my Nines a week ago. It is because the Nines put out so much more bass than the Sevens. I had to do a lot of playing around with placement to get a handle on that issue. Still working on it actually. Unless you are running them for HT I am not even sure you need a sub for them they put out so much bass for their size. I run a small MicroPro 2000 with them currently but only from 60hz on down. I wish they could somehow be designed so that the port was in front - maybe that would reduce the reflections. I know the PowerPort redirects the bass coming out of the ports outwards so it does not fire directly backwards, but I feel they sound better with a bit of toe-in so at least one side of the port will be bouncing midbass off the wall behind them if you don't pull them out as much as possible. The more the better. This is only an issue in my room at higher volumes.
  • dkg999
    dkg999 Posts: 5,647
    edited August 2010
    I would take the 7's integrated with a fast musical sub (think a sealed or PR type design such as the MicroPro) for a music focused system. The purity of the 2 way design coupled with a good sub is IMHO much cleaner and more focused as a music presentation than the 9's. I use 9's as my fronts in my HT and they are fantastic for that.
    DKG999
  • dondapatirc
    dondapatirc Posts: 1
    What is the difference between a modded LSI9 and unmodded one? How different is the sound gonna change?
    Could you let me know where can we get the crossovers modified??
    thanks,
    Don
  • PSOVLSK
    PSOVLSK Posts: 5,400
  • dorokusai
    dorokusai Posts: 25,576
    LSi7.
  • Mikey081057
    Mikey081057 Posts: 7,127
    I have both...and both work well... the 7's though sound a little light in bass, and would need a sub.
    You can get away without a sub with the 9's. My 9's do have the famous VR3 Fortress mod.
    Garage | Polk Monitor 5B's
