LSi9 vs LSi7
cokewithvanilla
I was going to buy the 9's for my apartment when I go back to school in a few weeks, but I read a thread that said better things of the 7's than the 9's (not that I believe everything I read, but it surprised me)....
I've heard such great things about the 9's, though I've heard little of the 7's. Anyone have thoughts on this matter?
They will be powered by an adcom gfa-5800, signal cable, a random computer (hopefully digital out, I suppose that will depend on the pre).
Post edited by cokewithvanilla on
When I was on a speaker buying trip, I was looking at some Klipsch bookshelves and the salesman showed me a set of LSi7's. They were much better than the Klipsch models I was listening to, and I was ready to jump on them. He then said "before you make up you mind, you need to hear these" and turned on the 9's. The 7's weren't even in the same ballpark. I bought the 9's. Good salesman.
I'm really enjoying my 9s and would recommend them to anyone. Especially for small apartment size/type rooms. They easily fill it and I've been asked several times where my sub was. (I don't have one). I'm don't think the 7s have the same bass response in comparison. There's other differences that I can't recall right now. Google Lsi7 vs Lsi9.
If you've got good, and I mean good amplification, go with the 9's. Then save up to mod the x-overs.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
I liked the 7's much better for music. They had a special quality which my 9's didn't, I think due to the simpler crossover.
Thanks for the replies.
I listed the amplifier in the first post... I've used it on my 25's and compared it to the the 7270, I think I can tell a subtle difference.
With that amp and an equivalent pre, which speakers will (should) sound better? Modding the xo's sounds like something I would do in the future. -
I have read that the 7s are really a 6 ohm speaker whereas the 9s are a true 4 ohm if that makes a difference. I have not heard the 9s unfortunately, but I LOVE my 7s, best speakers I have ever heard (which of course tells you that I am not the person to ask
) I don't know about your amp, but if you are worried about power and have a musical sub, go with the 7s. I wouldn't run the 7s without a sub except in a small office or dorm for background music, if you are going to use them for any gaming/music or just bass heavy music, I think you need a sub. Just my 2 cents.
Peace,
PaulLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Loved my 7's when I had them, they were no Magnepan's but wow did they sound gorgeous!
Other than proper amplification, I hope you're running a good pre and source...those speakers can be pretty damn detailed.
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Alright, well I guess I should ask this: is the second driver in the LSi9 simply a low range driver? What frequencies does it handle?
I would be using this in my small apartment for music mostly. I haven't decided on a preamp... something simple with digital, i'd imagine (any thoughts are welcome too) -
anonymouse wrote: »I'm sure the 7s are easier to drive than the 9s. But the 9s with modded crossovers and proper amplification are heavenly.
What he said!
Listening to an old Grant Green jazz CD on modded 9s now and its like I've got the band in the living room.2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects -
cokewithvanilla wrote: »Alright, well I guess I should ask this: is the second driver in the LSi9 simply a low range driver? What frequencies does it handle?
http://www.polkaudio.com/homeaudio/lsi/specs.php#bookshelf -
I've had both speakers. I preferred the 7's for music and the 9's for HT. I should advise that when I had the 9's I was new to the hobby and didn't experiment with placement before I sold them for the 7's. At the time the 9's sounded muffled or something. I love my modded 7's for music, thoughMain Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
Second mid runs 200hz and down. Other mid runs full-range. Nines are better in a room where you can pull them well away from walls and sit at least several feet back for listening position. They do put out a surprising amount of bass for their size, which makes placement more critical than with some speakers since you may have issues with reflections due to the ports being in the back...
That being said, the Nines are a much more full-sounding speaker than the Sevens, and can handle a lot more power. I have not heard that the Sevens are 6ohm - nominal is listed as 4ohm just like the Nines. The nines can even dip below that at some points, and with their hefty power requirements you definitely will want a beefy amp. No receiver I have ever seen will really cut it, 4ohm stable or not. I am running 185wrms per channel to them and most folks on here would tell you that is not even enough to get the best performance out of them...
Hope this helps. Either way, nice speakers.Polk LSi-9s and Micropro 2000 sub
Asus Xonar Essence ST 24-bit soundcard ASIO
Kimber PBJ interconnects
Emotiva USP-1 analog preamp
Emotiva UPA-1 monoblocks
JRiver media player (upsampling to 24/192) -
I thought the same thing when I first got my Nines a week ago. It is because the Nines put out so much more bass than the Sevens. I had to do a lot of playing around with placement to get a handle on that issue. Still working on it actually. Unless you are running them for HT I am not even sure you need a sub for them they put out so much bass for their size. I run a small MicroPro 2000 with them currently but only from 60hz on down. I wish they could somehow be designed so that the port was in front - maybe that would reduce the reflections. I know the PowerPort redirects the bass coming out of the ports outwards so it does not fire directly backwards, but I feel they sound better with a bit of toe-in so at least one side of the port will be bouncing midbass off the wall behind them if you don't pull them out as much as possible. The more the better. This is only an issue in my room at higher volumes.Polk LSi-9s and Micropro 2000 sub
I would take the 7's integrated with a fast musical sub (think a sealed or PR type design such as the MicroPro) for a music focused system. The purity of the 2 way design coupled with a good sub is IMHO much cleaner and more focused as a music presentation than the 9's. I use 9's as my fronts in my HT and they are fantastic for that.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
What is the difference between a modded LSI9 and unmodded one? How different is the sound gonna change?
Could you let me know where can we get the crossovers modified??
thanks,
Don -
http://www.polkaudio.com/forums/showthread.php?134268-Polk-Audio-LSi15-Crossover-Modification-Thread
VR3 modsThings work out best for those who make the best of the way things work out.-John Wooden -
LSi7.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I have both...and both work well... the 7's though sound a little light in bass, and would need a sub.
You can get away without a sub with the 9's. My 9's do have the famous VR3 Fortress mod.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
