Has anybosy benifted biwiring with correct cables?
dekuda
dekuda Posts: 756
Has anybody out there benifted biwiriing their speakers with the proper biwire speaker cable? I have someone selling a older set of PNF Audio speaker cables that are biwire. Knowing that you should have differant paths for the low and high frequenzy connections I know that PNF and MIT are two that do this properly. I have read posts that say there have been no benifits of biwiring eventhogh many speaker manufacturers including Polk suggests improvements . And if there is no improvement could i just hook up both ends to the positive and both ends of the other to the negative and increase the guage of the cable?:confused:
HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
Post edited by dekuda on
  • fbm211
    fbm211 Posts: 1,488
    edited August 2010
    Yes,you can combine them to increase the guage as I have done with my signature cables.
    Try it both ways and decide what you like best.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • Face
    Face Posts: 14,340
    edited August 2010
    A couple pieces of high quality wire as jumpers also works well.
    edited August 2010
    Yes and no...yes if your gear is revealing enough,and if you use seperate amplification,then sometimes you can benefit. No...if your gear is entry level, and your just useing an avr, then probably not. This is not written in stone either. Of coarse every situation is different and the only way to know for sure is by trial and error. You could always resell what you don't like.
  • dekuda
    dekuda Posts: 756
    edited August 2010
    tonyb wrote: »
    Thanks guys! I have a Parasound HCA1500A amp in which I am thinking of doing this to drive my rti12's. Depending on what I can get this PNF speaker cable for I may just try it.The PNF is not the symphony model so I am not sure what I am getting. That being said hopefully it is good quality cable since it does say PNF.
    HT System
  • greene1968
    greene1968 Posts: 126
    edited August 2010
    i tried it..couldnt tell any difference. I was told bi amping is noticable though
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2010
    Bi-wiring with MIT bi-wire cables makes a very noticable improvement in the SQ. My experience with just using straight speaker cables to bi-wire revealed no improvement whatsoever.
    Bi-amping is a completely different story. Here's my experience bi-amping using a Parasound HCA 1000A on the highs and a set of strapped Adcom 565 mono blocks on the lows
    http://www.polkaudio.com/forums/showthread.php?t=50391&highlight=biamped+1.2tls
