Down and dirty amp audition
EndersShadow
EndersShadow Posts: 17,715
So I am going to be the potential proud owner of a Carver av-705x amplifier this weekend. I however need help auditioning it. The owner hasnt used it in years so I want to verify all channels work.
This is what I am thinking. One by one check each channel using a CS1 speaker getting its input from one side of a y cable coming from a ipod....Will this work?
I am trying to avoid disconnecting my entire reciever to connect out there to verify all channels work. I thought this way I could test each channel individually quickly without nearly as much hassle and cords.
Post edited by EndersShadow on
    nooshinjohn Posts: 25,973
    edited July 2010
    bring it up to my place and we can plug it into my rig if you like.:p
    That method will work, but you will not get a feel for what the amp can do without wiring it up properly. There is a chance, though small, that even though each works ok on their own, that there could be a problem when all channels are driven.
    edited July 2010
    Lol....I just want to use that method to test to ensure that all the channels are working. As long as I can get 3 of the 5 channels working I call it a win personally as the emotiva XPA-3 costs 600ish and that is not anywhere near what I can spend. Also that way if a couple dont work I can negotiate the price down.
    I may have you come down if you are around to help me dial it in if I have trouble (which I hope I wont). Also if it doesnt make a huge difference to how things sound (which I am pretty sure it will) I will give you first dibs on it. :)
    edited July 2010
    Looks like he is going to pass by my work tomorrow so I am just going to purchase it on pure faith alone.....
    Lets hope it all goes well :)
