SDA 2Bs
mole'
so i have been looking around for some new Front speakers and a guy(somewhat) local to me has some up for grabs.
he has a few sets of them. SDA SRS in great condition, SDA SRS, SDA 1, SDA 2B and a set of SDA 2B is so-so condition. he said one of the tweeters needs to be replaced. $250 for that set. is this a good deal or should i look around some more.
here is his ebay listing for a set of his SDA SRS.
http://cgi.ebay.com/Polk-Audio-SDA-SRS-Signature-Reference-Speakers-/190419644946?cmd=ViewItem&pt=Speakers_Subwoofers&hash=item2c55e53212
mole'
Post edited by mole' on
Seems to me the guy is on crack... The SRS are WAY overpriced given the overall condition and the fact they are not TL's...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Crack pipe!!!!I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
What's Crack???
when i went to his house to pick up an amp i got from him. he told me he would do 1800 for them.
but what about the price on the SDA 2Bs?? is that good or look around?mole' -
SDA 2B's that need a replacement tweet is not a very good deal because you will really have to get two RDO 194's to sonically match. Now you are talking 350.00 For that much money they should be in excellent condition with the interconnect cable. It's a little high in my opinion.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
I'd need to know more about their condition: are they in "so-so" condition because one of the tweeters needs to be replaced, or are they in "so-so" condition and one of the tweeters needs to be replaced?
If they are in otherwise great shape I'd say that 250 is a good deal, especially if you were going to buy the RD0's anyway, cuz then you're really only out one sl2000 which is only worth 20-30 bucks.
If they're all screwed up then it really depends how screwed up they are. That could be a bad deal if they're screwed up enough.
Did you see them when you were over there?2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Also I don't know how well the SDA's will match up with your monitors... that's what you're planning on doing, right... replacing the M70's in your sig with these 2B's? If that's the case you may need to look at a different speaker.
What would you be powering them with.. that GFA 545?2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
mole, some more SDA 2B pricing
http://www.jaxed.com/cgi-bin/sd.cgi?cat=ele&fil=sda+2b&state=&submit=go--Gary--
yes i saw them in person. he has 8 sets of SDAsfalconcry72 wrote: »I'd need to know more about their condition: are they in "so-so" condition because one of the tweeters needs to be replaced, or are they in "so-so" condition and one of the tweeters needs to be replaced?
they are so-so cause of the tweeter and on the front of one it has a scuff mark. nothing bad. i would say a 8/10. he had a set of SDA 2Bs that are 10/10 and he wanted 500 for them.mole' -
falconcry72 wrote: »Also I don't know how well the SDA's will match up with your monitors... that's what you're planning on doing, right... replacing the M70's in your sig with these 2B's? If that's the case you may need to look at a different speaker.
well my Monitor 70s are a lil messed up right now. so its get them fixed or buy some better speakers.
i have 2 Amp. the Adcom GFA-545 MkII and an Acurus 250x3. i would use the Acurus for these speakersmole' -
all about the same price as this local guy. i need to try and talk him down some and show him these prices
Thanksmole' -
Better speakers than these pop up all the time in SoCal my friend... If they are damaged in ANY way for those prices, don't walk away... RUN!!!
This link will be your friend. I don't share it with anyone, so please don't share it for any reason with the loonies here or they will get them before you do...
www.craiglook.com
...did I just say that
:eek::p:D The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »Better speakers than these pop up all the time in SoCal my friend... If they are damaged in ANY way, don't walk away... RUN!!!
www.craiglook.com
:eek::p:D
LOL, thanks manmole' -
found these, but not sure what series
http://sandiego.craigslist.org/esd/ele/1868131855.html
http://losangeles.craigslist.org/sfv/ele/1865308626.html
http://lasvegas.craigslist.org/ele/1862550552.html
monitor series 10
http://losangeles.craigslist.org/sgv/ele/1857804553.html
monitor 50s and monitor 70s for sale. might get one of the 70s and use it for spare parts to repair my current 70s
http://orangecounty.craigslist.org/ele/1793829386.html
http://orangecounty.craigslist.org/ele/1793829386.htmlmole' -
I understand SDA 2B's might not match your current speakers in play, and the particular set you are looking at may be damaged, but want to mention the following . . .
Stock 2B's are a fine speaker in their own right and mine performed well since I bought them brand new at the end of 1987, however . . .
--- stock SL2000 tweeters are harsh and (in my opinion) should be replaced (can be resold if working)
--- capacitors and resistors in the 20+ year old crossovers should be replaced no matter what.
If you are going to the trouble of rebuilding the crossovers, you might as well spring for the 2 extra 5.8uf caps needed to allow for the use of RDO198-1's and "TL" the beasts.
My point is, to bring SDA 2B's into a state where they are one of the best sounding speakers around, you should plan on spending . . .
--- about $250 for caps and resistors
--- $96 for 2 new RDO tweeters
--- about $50 for Cardas binding posts
--- about $20 for Dynamat Extreme
--- about $10 for Mortite or other speaker sealing compound
--- about $70 for a new Interconnect Cable and connections
In other words, add about $500 and some time to your base cost of the speakers.
(If any of the Mid Woofers are damaged, plan on another $48 each to replace, and if a Passive Radiator is damaged, maybe $40 on the pre-owned market will buy one.)
LAST . . . I'm guessing you might pay $2,000 or more for a new pair of speakers comparable to what you will end up with if you buy, restore and "TL" Polk SDA 2B's.
P.S.: mole', Welcome to Club Polk!
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
inspiredsports wrote: »I understand SDA 2B's might not match your current speakers in play, and the particular set you are looking at may be damaged, but want to mention the following . . .
WOW, had no idea about all of that.
thanks for opening my eyes up.mole' -
I recently TL'd and broke-in my 2B's and all I say is WOW!! It turns into a completely different speaker, with a huge sounds stage for the speaker size. Worth every penny if you want awesome clear sound without a monster set of speakers filling your room space.
You liking them more than your 1C's now? I saw them on ebay! -
inspiredsports wrote: »Stock 2B's are a fine speaker in their own right and mine performed well since I bought them brand new at the end of 1987
or buy them for 250.00 get a replaceent tweeter and enjoy a fine speaker
just saying, everthing listed can be done, but not required to enjoy a pair of 300.00 floorstanding speaker.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Clever Sherlock
I do prefer SDA-2B's with fully upgraded XO's/TL'd to "STOCK" 1c's.....but not to my modded 1C's though. Comparing both modded speakers, they are close but the better mids in the 1C's give it the notch up. -
We Agree!
Line 2 of my original post was "Stock 2B's are a fine speaker in their own right and mine performed well since I bought them brand new at the end of 1987, . . . "
. . . however, 23-year old caps have most likely drifted off of their original values, maybe enough to make a fairly substantial audible diference.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
gotta keep an eye out for some in the SoCal area.
i will buy a set sooner or latermole'
