SDA 2Bs
mole'
mole' Posts: 3,160
edited July 2010 in Vintage Speakers
so i have been looking around for some new Front speakers and a guy(somewhat) local to me has some up for grabs.
he has a few sets of them. SDA SRS in great condition, SDA SRS, SDA 1, SDA 2B and a set of SDA 2B is so-so condition. he said one of the tweeters needs to be replaced. $250 for that set. is this a good deal or should i look around some more.
here is his ebay listing for a set of his SDA SRS.
http://cgi.ebay.com/Polk-Audio-SDA-SRS-Signature-Reference-Speakers-/190419644946?cmd=ViewItem&pt=Speakers_Subwoofers&hash=item2c55e53212
mole'
Post edited by mole' on
    nooshinjohn Posts: 26,000
    edited July 2010
    Seems to me the guy is on crack... The SRS are WAY overpriced given the overall condition and the fact they are not TL's...
  • concealer404
    concealer404 Posts: 7,440
    edited July 2010
    Crack pipe!!!!
    Toolfan66 Posts: 18,183
    edited July 2010
    What's Crack???
  • mole'
    mole' Posts: 3,160
    edited July 2010
    when i went to his house to pick up an amp i got from him. he told me he would do 1800 for them.
    but what about the price on the SDA 2Bs?? is that good or look around?
    mole'
  • bluecomet
    bluecomet Posts: 1,118
    edited July 2010
    SDA 2B's that need a replacement tweet is not a very good deal because you will really have to get two RDO 194's to sonically match. Now you are talking 350.00 For that much money they should be in excellent condition with the interconnect cable. It's a little high in my opinion.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • falconcry72
    falconcry72 Posts: 3,580
    edited July 2010
    mole' wrote: »
    I'd need to know more about their condition: are they in "so-so" condition because one of the tweeters needs to be replaced, or are they in "so-so" condition and one of the tweeters needs to be replaced?
    If they are in otherwise great shape I'd say that 250 is a good deal, especially if you were going to buy the RD0's anyway, cuz then you're really only out one sl2000 which is only worth 20-30 bucks.
    If they're all screwed up then it really depends how screwed up they are. That could be a bad deal if they're screwed up enough.
    Did you see them when you were over there?
  • falconcry72
    edited July 2010
    Also I don't know how well the SDA's will match up with your monitors... that's what you're planning on doing, right... replacing the M70's in your sig with these 2B's? If that's the case you may need to look at a different speaker.
    What would you be powering them with.. that GFA 545?
  • halo71
    halo71 Posts: 4,638
    edited July 2010
    --Gary--
  • mole'
    mole' Posts: 3,160
    edited July 2010
    yes i saw them in person. he has 8 sets of SDAs
    they are so-so cause of the tweeter and on the front of one it has a scuff mark. nothing bad. i would say a 8/10. he had a set of SDA 2Bs that are 10/10 and he wanted 500 for them.
    mole'
  • mole'
    mole' Posts: 3,160
    edited July 2010
    well my Monitor 70s are a lil messed up right now. so its get them fixed or buy some better speakers.
    i have 2 Amp. the Adcom GFA-545 MkII and an Acurus 250x3. i would use the Acurus for these speakers
    mole'
  • mole'
    mole' Posts: 3,160
    edited July 2010
    halo71 wrote: »
    all about the same price as this local guy. i need to try and talk him down some and show him these prices
    mole'
    edited July 2010
    Better speakers than these pop up all the time in SoCal my friend... If they are damaged in ANY way for those prices, don't walk away... RUN!!!
    This link will be your friend. I don't share it with anyone, so please don't share it for any reason with the loonies here or they will get them before you do...
    www.craiglook.com
    ...did I just say that:confused::eek::p:D
  • mole'
    mole' Posts: 3,160
    edited July 2010
    Better speakers than these pop up all the time in SoCal my friend... If they are damaged in ANY way, don't walk away... RUN!!!
    www.craiglook.com
    LOL, thanks man
    mole'
  • inspiredsports
    inspiredsports Posts: 5,502
    edited July 2010
    I understand SDA 2B's might not match your current speakers in play, and the particular set you are looking at may be damaged, but want to mention the following . . .
    Stock 2B's are a fine speaker in their own right and mine performed well since I bought them brand new at the end of 1987, however . . .
    --- stock SL2000 tweeters are harsh and (in my opinion) should be replaced (can be resold if working)
    --- capacitors and resistors in the 20+ year old crossovers should be replaced no matter what.
    If you are going to the trouble of rebuilding the crossovers, you might as well spring for the 2 extra 5.8uf caps needed to allow for the use of RDO198-1's and "TL" the beasts.
    My point is, to bring SDA 2B's into a state where they are one of the best sounding speakers around, you should plan on spending . . .
    --- about $250 for caps and resistors
    --- $96 for 2 new RDO tweeters
    --- about $50 for Cardas binding posts
    --- about $20 for Dynamat Extreme
    --- about $10 for Mortite or other speaker sealing compound
    --- about $70 for a new Interconnect Cable and connections
    In other words, add about $500 and some time to your base cost of the speakers.
    (If any of the Mid Woofers are damaged, plan on another $48 each to replace, and if a Passive Radiator is damaged, maybe $40 on the pre-owned market will buy one.)
    LAST . . . I'm guessing you might pay $2,000 or more for a new pair of speakers comparable to what you will end up with if you buy, restore and "TL" Polk SDA 2B's.
    P.S.: mole', Welcome to Club Polk! :)
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • mole'
    mole' Posts: 3,160
    edited July 2010
    WOW, had no idea about all of that.
    thanks for opening my eyes up.
    mole'
  • Hamatym
    Hamatym Posts: 269
    edited July 2010
    I recently TL'd and broke-in my 2B's and all I say is WOW!! It turns into a completely different speaker, with a huge sounds stage for the speaker size. Worth every penny if you want awesome clear sound without a monster set of speakers filling your room space.
  • nduitch
    nduitch Posts: 316
    edited July 2010
    Hamatym wrote: »
    You liking them more than your 1C's now? I saw them on ebay!
  • hoosier21
    hoosier21 Posts: 4,420
    edited July 2010
    or buy them for 250.00 get a replaceent tweeter and enjoy a fine speaker
    just saying, everthing listed can be done, but not required to enjoy a pair of 300.00 floorstanding speaker.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Hamatym
    Hamatym Posts: 269
    edited July 2010
    nduitch wrote: »
    Clever Sherlock ;) I do prefer SDA-2B's with fully upgraded XO's/TL'd to "STOCK" 1c's.....but not to my modded 1C's though. Comparing both modded speakers, they are close but the better mids in the 1C's give it the notch up.
  • inspiredsports
    edited July 2010
    hoosier21 wrote: »
    We Agree!
    Line 2 of my original post was "Stock 2B's are a fine speaker in their own right and mine performed well since I bought them brand new at the end of 1987, . . . "
    . . . however, 23-year old caps have most likely drifted off of their original values, maybe enough to make a fairly substantial audible diference.
    NAD SS rigs w/mods
    GIK panels
  • mole'
    mole' Posts: 3,160
    edited July 2010
    gotta keep an eye out for some in the SoCal area.
    i will buy a set sooner or later
    mole'
