Bi-amping not going well...help please!
BrentAric
I joined hoping I could find a little help. Please forgive my lengthy question.
The problem: I am trying to bi-amp my two-channel system and as soon as I power up, I hear a terrible sound and fuses blow in my amps.
More specifically:
I have a Rotel RC-1070 preamp which has dual amplifier outputs.
I have been running one Adcom GFA-535 into my Linn Keilidh speakers using Linn LK400 speaker wire.
I decided to add a second Adcom GFA-535 in order to bi-amp (known as passive bi-amping to be specific). This, I know, will only give me modest sound gains at best, but I needed to fill a spot on my setup and thought it would be fun to try.
So, I bought a second GFA 535 which arrived today.
For the last six hours I've had nothing but failure.
Each amp works fine on its own.
I connected the positive treble wire to the treble input on the Linns to one amp, and the positive bass wire to the bass input on the Linns, the treble and the bass each of course connected to a different amp.
In other words, one amp was to power the tweeters the other the drivers.
My power comes through a Rotel line conditioner.
As soon as the Adcoms received power when bi-amped...I'd hear "ZIP!" the fuses all blow in the bass amp and none or some in the treble amp.
After trying this three times I gave up...I don't have any more fuses!
There are passive diagrams for bi-amping online and it would seem I'm doing things right. I am at a loss and really frustrated.
I'm at my wit's end and desperate for some input. Any thoughts?
Thanks in advance-
Brent
More specifically:
Thanks in advance-
Brent
Post edited by BrentAric on
Did you remove the jumpers on the binding posts?Political Correctness'.........defined
President of Club Polk -
What did you do with the negative wires?If you can't hear a difference, don't waste your money. -
That comment struck me as odd as well.Political Correctness'.........defined
Besides the question of the negative wires, which I don't think you are that goofy not to hook up properly, I question the use of the Rotel RC-1070 preamp dual amplifier outputs. I've found that in the higher end preamps that have two outputs, one is for DC coupled amps, the other for AC coupled amps.
This is an excerpt from my Spectral DMC 10G preamplier user manual;MAIN OUTPUT – DC COUPLED. These outputs are controlled by the volume and balance controls. They are coupled for flat gain to DC. it is important that these outputs only be used with AC coupled amplifiers.
MAIN OUTPUT – AC. These outputs are the same as those above except the signal is coupled through 10uF film capacitors. These outputs may be used with direct-coupled amplifiers.
CAUTION; ONLY ONE OUTPUT SHOULD BE USED AT ANY GIVEN TIME. USING THE TWO OUTPUTS TOGETHER CAN CAUSE DAMAGE TO THE PREAMP OR AMPLIFIERS.
I spoke with the engineer at Spectral and he advised that the DC coupled outputs ONLY be used with a Spectral amplifier. He said that even if the amplifier I am using IS DC coupled do not use the DC coupled output as it may be a mismatch with the Spectral DC coupled stage of the preamp.
This link describes how I biamped my 1.2 TLs;
http://www.polkaudio.com/forums/showthread.php?t=50391&highlight=biamped+1.2tls
I hope this helps you with your problem. To summarize use a 'Y' connector on just one of your preamps outputs. -
Good call Joe, but we may never know for sure untill the OP gets a tad more specific on his connections.HT SYSTEM-
lsi 9's -
Just a suggestion for bi-amping. Instead of trying to run the tweeters on one amp and the woofers on another, just switch each amp to mono (not bridged) and use one amp to drive the left channel and one to drive the right. I run mine that way without problems, and I got more than a modest gain in sound quality. It also lets you avoid having to use splitters.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Sorry about the lack of clarity on my original post. The negative "black" wires are of course matched to their appropriate inputs on the amp. I typed the original while stressed out and wasn't thinking clearly.
The Rotel manual says:
"There are two sets of variable gain outputs on
the RC-1070. The second set of outputs may
be used in custom system configurations to drive
a second power amplifier or to supply a sig-
nal to a signal processor."
There are three sets of inputs on the back of my Linn speakers. The top is treble, the middle bass, the bottom bass. The middle and bottom are connected with jumpers. According to the Linn dealer the jumpers should only be removed if I am tri-amping with a Linn Aktiv system. When going Aktive, the dealer (or me) would disable the internal crossovers. Does that sound logical?
Quadzilla, I don't think my Adcom GFA 535's can be made mono, can they? That is a nice option, but I don't think I can make them mono.
Is it possible that both amps coming on at the same time (the Rotel line conditioner turns them on at the same time) is the problem?
THANKS for all the input. I appreciate all of it.
Brent -
Brent
The only thing I would add to that is, does the manual state that you can use both outputs simultaneously? Also, is there a switch that you may have missed on the back that allows the amps run simulataneously?
Other than that I would check with the speaker manufacturer and make absolutely sure the jumpers are in the right place.
If all else fails, try the 'Y' connector configuration. -
Disaster again.
I just tried plugging everything into the line conditioner but turning things on myself. Turned on my sources. No problem.
Turned on the treble amp. No problem.
Turned on the bass amp...it blew. -
Disaster again.
Have you tried plugging the amp directly to the wall outlets.
Also, have you switch amps from bass to treble and visa versa and turned them on one at a time? If so did the same amp cause the blowout? If so you've got a problem with your one amp.
I just thought of this although it's off the wall but do the Linns require common ground amplifiers? -
They can't.If you can't hear a difference, don't waste your money. -
Dunno if this helps, but this is my experience with bi-amping with 535's,,,pre out--used a "y" splitter-- one pair of red/black to each amp.L&R speaker connections to bass from one amp----one pair of speaker cables to tweeters,, be sure that you have the "jumper cables" removed from the speakers.In the end I settled for a pair of small tube monoblocks--but,,good luck and keep us posted.JC approves....he told me so. (F-1 nut)
They can't.
you are correct sir,, the Adcom 535's are a dual mono amp,sweet little puppies too.JC approves....he told me so. (F-1 nut) -
Ah well.Turntable: Empire 208
Arm: Rega 300
All:
I'm ashamed to admit all it required, as advised, was removing the second set of jumpers from my Linn speakers.
As we speak my kids are listening to Lady Gaga in the living room (no comment required) with both amps doing their jobs beautifully.
I wish I knew how to post a photo, the end results looks great.
In terms of sound, bass is more "gentle" and easier sounding and it images away from other sounds better. I broke out my MFSL Ultradisk of Rush's Signals album and the difference was very apparent.
Thanks again everyone, very nice forum and people.
Brent -
I knew it. Glad you're enjoying the improvement.Political Correctness'.........defined
For the record I like Lady GaGa.. I find her CD to be very well recorded..
Glad your up and running... -
Who is Lady gaga? Good to hear that you got it worked out.JC approves....he told me so. (F-1 nut)
Okay, I'll admit it...I like her too. Quite a bit.
Good call on the jumpers. -
You shouldn't allow Lady Gaga to break in the new amp, or it will sound awful for the rest of it's existence like Lady Gaga does.
Obviously this is a joke
I'm sorry for all of you that admitted you like her :P Jumper plates were my guess too. Fronts: DIY Statements from htguide.com
Center: DIY custom Statement center from htguide.com
Surrounds: Four DIY custom Mini Statements
Wire: HD-14
Receiver: Denon AVR-4806 + CI upgrade
Amps: Dual Emotiva LPA-1's
Sub: Infinite Baffle: 8 fiCarAudio IB315 woofers, Behringer DSP1124P EQ, Elemental Designs eQ.2, Dual EP4000 amps
Transducers: 2 buttkicker LFE's, BK amp, EQ'd w/DSP1124p
DVD: Toshiba HD-XA2 / PS3
TV: Samsung 1080p 61" DLP -
Oh that's okay. I listened to Spoon's newest album Transference on vinyl, the above mentioned MFSL copy of Rush's Signals, then my all time favorite album, Amused to Death by Roger Waters, which I'm lucky enough to also have an original master recording of.
However, the new amp has also helped play a lot more Lady Gaga, Ke$ha and other stuff like that in the last 24 hours. I'm just happy my daughter wants to use our main stereo and not the little one in her room!
Brent
