Speaker wire
Kresto
Kresto Posts: 12
edited July 2010 in Speakers
Hello gang, just wanted to get some input from the speaker guru's on here if I may.
I have an Onkyo TX-NR807, Ti200's for front, CS20 center, RTi-A1 for rears and a PSW110 sub.
Distance from receiver to center ch is 5', to fronts 12', to rears 25' and to sub 15'
I'll be running the center and front wires behind the entertainment center, so hiding them will be easy. The wires that run to the sub and rears will have to be next to or under the base board.
What speaker wire/wires would you recomn'd? I don't want to buy junk, however I don't want to take a 2nd on the house to buy wire. I figured there has to be something that sounds good for a decent price. Place to purchase?
Thanks in advance!
Post edited by Kresto on
  • Face
    Face Posts: 14,340
    edited July 2010
    For finished wires, check out www.SignalCable.com
    Unfinished, check out the Canare 4S11 at http://www.bluejeanscable.com/store/speaker/index.htm
  • gp4jesus
    gp4jesus Posts: 2,019
    edited July 2010
    Picked up a several 30' rolls of AR OFC 12 ga from Parts Express for less than $10 plus shipping.
    *all connected w/Premiere ICs
  • gp4jesus
    edited July 2010
    Be careful of the topic of "wire and interconnects."
    In my 30+ years around audio, w/out a doubt, the most controversial subject, short of Christ's divinity!
    check this link:
    http://www.diyaudio.com/forums/multi-way/15600-i-dont-believe-cables-make-difference-any-input-1490.html
    Started May 25th, 2003; nearly 15,000 replies (14,897)
    cheers tony
  • Kresto
    Kresto Posts: 12
    edited July 2010
    Thanks guys for all the great input, I didn't realize there was that many different configurations of audio cable. WOW!!
    Thanks again you've been a big help :)
  • dorokusai
    dorokusai Posts: 25,624
    edited July 2010
    Face wrote: »
    I agree and the Monoprice suggestion is also a good place to start. The rest of the thread garbage has been soft deleted.
  • ZeroCoolPolks
    ZeroCoolPolks Posts: 53
    edited July 2010
    300 ft of 16 ga. Oxygen Free from Monoprice 36 + SH is what I use for Monitors and all runs under 50 ft at 8 ohm's. Everything bi-wired.
    If the wire gauge is to small for the Ohms and run length, you'll heat up the AVR amps and prematurely kill it off, shorten it's life span.
