Theta transport repair
fbm211
fbm211 Posts: 1,488
edited July 2010 in DIY, Mods & Tweaks
I finally get the gear and it looks the same except for the belt.Thats okay though as the old belt seems fine.
However, after removing the transport I find that the gear (with half the teeth missing:eek:) is attached to a small metel plate that holds it in place.
If the gear can be removed I dont have the micro tool needed nor am I sure if it can be replaced.
Maybe someone here has experence with this sort of thing and can help me out:o..............Please.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • quadzilla
    quadzilla Posts: 1,543
    edited July 2010
    Might seem like a stupid question, but can't you just replace that whole assembly?
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    That would cost a-lot more.The CDM9pro is what I would need I think.
    Anyway that would be as a last resort.Theta put some sort of filter on the lens and a new one wouldnt have that filter.
    The sound of the theta transport is good enough that I will buy another one if I have to.
  • madmax
    madmax Posts: 12,434
    edited July 2010
    I took that gear out of mine and open the drawer manually. Where did you find the gear? I don't mind the manual usage given the sound of the transport. I've tried other transports but they just don't have the sound.
    Vinyl, the final frontier...
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    The gear is available on fleabay.It costs 13.00 and free shipping.From hong konk.I waited three weeks.
    CDM9 CDM9PRO CD Player Drawer Gear Wheel Repair replace
    Just paste above into ebay search.
  • madmax
    edited July 2010
    Thanks, I'll check it out. Here is an old thread where I tweaked mine. http://www.polkaudio.com/forums/showthread.php?t=23617&highlight=theta
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Awsome,I have a nice size piece of dynamat extreme.
  • madmax
    edited July 2010
    I put blu tac all over the transport too. It seemed worthwhile. I see an extra little circuit board in mine. That must be the power supply upgrade I was told about when I bought it.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Ive heard about that upgrade and would like to get it or do it myself but I cant find any info on what parts to get and where to put them.
    There are some caps that might benifit the SQ by replacing them.
    Or I may just send it to the upgrade company.
