Replacing attached power cords with IEC connector
quadzilla
quadzilla Posts: 1,543
edited October 2013 in DIY, Mods & Tweaks
Anyone have any good links with tips, or just have some experience with, replacing an attached power cord with an IEC connector?
Thanks,
Rob
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Post edited by quadzilla on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited July 2010
    Hello Rob,
    I've done a few of those. You can remove the existing power cord from the chassis, then use a "metal nibbler" to make a rectangular opening to fit the IEC socket. I usually will place masking tape over the intended area and then use a fine tip pen to draw the outline. The original hole, where the power cord went through, should give you a beginning place for the nibbler. Another approach is to use a rectangular chassis punch to create the hole. Then you can either use a "snap-in" IEC socket or one with mounting holes. The snap-in type will usually work with slightly thicker chassis metal and not be too lose. The mounting hole type requires two holes, obviously. You can find IEC sockets that built-in filters, etc.
    I hope this helps.
    Ken
    Toolfan66 Posts: 17,982
    edited July 2010
    Where is the best place to buy the sockets??
  • Face
    Face Posts: 14,340
    edited July 2010
    Parts Express, Sonic Craft, etc...
    edited July 2010
    Any quality ones to look for??
  • Face
    Face Posts: 14,340
    edited July 2010
    I've never made any comparisons between brands.
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2010
    I use a Dremel to make the socket hole. Any brand will do fine.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Here is a good socket at a good price.And its 20% off right now.
    >> http://www.soniccraft.com/products/connections/ac/socket/iec/furutech_fi10.htm
    They have some for 12.00 too.But Id go for one with screw terminals.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • quadzilla
    edited July 2010
    Thanks guys! That's exactly the info I was looking for. I thought it might be as easy as just cutting out the hole, but I haven't tried and it don't have any "spares" to experiment on. A dremel and masking tape I have. Using metal shears sounds like it might be more precise, but this is pretty heavy steel. Not sure I could get shears through it. The chassis punch isn't something I thought of. I'll have to look into that too.
    Arm: Rega 300
    edited July 2010
    Rob thanks for posting this thread. I want to do my Pioneer SC-07.
  • quadzilla
    edited July 2010
    You're most welcome. I'm thinking my SC-05 and the Mackie amps will get this treatment. I got some Pangea PCs after seeing how much people liked them in the other thread. They lowered the noise floor in all my sources considerably, including getting rid of a very slight hum in one. I'm thinking that replacing the PCs on the rest of the gear is the next logical step to see if that gets rid of a very slight hum in the amps I've never been able to completely vanquish. I certainly noticed an immediate improvement in sound, and the improvements are all easily attributable to the lower noise floor.
    Arm: Rega 300
  • Conradicles
    Conradicles Posts: 6,325
    edited July 2010
    That is it, I'm getting off the fence and doing this to my Denon Power Amp. Thanks for the info guys.
    F1nut Posts: 51,673
    edited July 2010
    The Furutech IEC's are excellent.
    A word of caution before cutting and drilling. Make sure you're not going to hit anything inside the chassis and make sure that there is actually room to mount an IEC.
  • quadzilla
    edited July 2010
    Anyone have a manf. or link to a chassis punch? The only one I've found so far in the right size was ~450 bucks. If not, guess I'll be getting out the good ol' dremel in a few.
    Arm: Rega 300
  • [Deleted User]
    edited July 2010
    I don't have a specific part number, but Greenlee is the company most known for chassis punches. Try Mouser's catalogue.
  • [Deleted User]
    edited July 2010
    I looked in Mouser's catalog and didn't find anything specific to recommend. The square chassis punches are very expensive. My nibbler tool will cut up to 18 gauge (.046") steel and 1/16" aluminum and with a little practice can make an almost perfect rectangle. The nice thing about the nibbler is you can control the cuttings. Each time you take a "bite" the small residue comes away with the tool. You can make sure there's no metal shavings to worry about. That's handy when the piece of equipment is occupied.
    I keep an eye out on CL for Greenlee punches all the time but haven't found a square one.
    Cheers, Ken
  • polrbehr
    polrbehr Posts: 2,842
    edited July 2010
    It's pretty simple to do, and worth it.
    FWIW, I used a Dremel and a nibbler tool, either one will work fine, but the nibbler makes the cutouts nice and neat.
  • quadzilla
    edited July 2010
    OK. I checked a couple of hardware stores for a nibbler, but no luck. Guess I'll try some more.
    Arm: Rega 300
  • george daniel
    george daniel Posts: 12,096
    edited July 2010
    Ken,, how would you wire an IEC when the cord that you are replacing is two pronged?I'm not an EE,,hence the elementary question.I'm struggling because the IEC has 3 vs 2 (stock power cord on amp which is captive)
    Thanks.
  • [Deleted User]
    edited July 2010
    They can be found in Mouser's catalog and GC Chemicals.
  • Face
    Face Posts: 14,340
    edited July 2010
  • [Deleted User]
    edited July 2010
    Hello George,
    The three prong cord has a "hot" and a "neutral", which are side-by-side and ground connection that is a round pin. Your audio component will just have a hot and neutral wire to connect. If you were to hold the IEC socket as if it were already installed in the component's chassis and the ground lug were on top, the "hot" would be the left prong and the "neutral" would be the right prong. As far as your component's hot and neutral wires, the best approach would be to use two "alligator-clip leads" and a VOM. Use the clip leads to connect the component's bare wires to the hot and neutral terminals of the installed IEC socket. Then, with the component turned on, use the VOM to measure the AC voltage between the component's chassis ground and the neutral terminal. Then, after turning off the component, reverse the two wires on the two IEC terminals. Remeasure between the chassis ground and the neutral IEC terminal. Pick the connection that has the lowest voltage present between the chassis ground and the neutral terminal.
    There won't be anything connected to the IEC ground terminal.
    I hope this is helpful.
    Ken
  • quadzilla
    edited July 2010
    Face wrote: »
    Ah, thanks, that would be what I'm looking for. One hardware store tried to sell me some electric shears for 190. That was a bit more than I was prepared to spend for this project for just tools.
    Arm: Rega 300
  • quadzilla
    edited July 2010
    Guess it'll be a dremel... The Mackies are 14 ga steel.
    Arm: Rega 300
  • george daniel
    edited July 2010
    Hello George,
    Ken
    Perfect-thanks Ken.
  • carvcom
    carvcom Posts: 240
    edited July 2010
    Hey guys,
    I know it's a few days later, but, I installed these on all 3 of my Carver amps. I would highly recommend removing the rear panel before attacking it with a dremel or shears. I actually had a machinist buddy hog mine out with an end mill with great results.
    Just my 2 cents.
  • [Deleted User]
    edited September 2010
    Hello,
    I've dug up some additional information on finding a suitable chassis punch. A Switchcraft IEC socket measures 1.19" wide and 0.81" high. The Greenlee chassis punch 60040 will make a hole 1.181" by 0.866" that should be a very good fit. Next step is to save up $350.00 and buy one, I'll let everyone know the results.
    Cheers, Ken
    pitdogg2 Posts: 26,927
    edited October 2013
    Hello,
    Cheers, Ken
    That looks like the next big thing from Larry(toolfan). I can't believe those are that pricey 350.00/500.00 for the same tool...crazy prices. I can see spending that much IF I did 4-5 a day it would pay for itself, but 3-4 over 8-10 yrs not so much....
