Time to hear a better 2 channel
muncybob
muncybob Posts: 3,354
edited July 2010 in 2 Channel Audio
Currently all I have to drive my speakers is a Yamaha RX-V1400. Apparently I am missing a lot by relying on this AVR for my 2 channel music so I'm looking at picking up a 2 channel amp to drive my fronts(Vandersteen 2CE) and hear what I've been missing. At this time I can only afford to buy used and I'm concerned that just as my SDA 2B's crossovers need to be upgraded for max benefit won't I run into the same thing with an older amp? ...and while I'm at it, any suggestions on a low priced high current amp that will improve my world?
Yep, my name really is Bob.
Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub.
  • miner
    miner Posts: 1,305
    edited July 2010
    A used Rotel RB-1080 (200w x 2) should do the trick. I had a RB-1070 (130w x2) that drove a pair of B&W N804 just fine.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2010
    muncybob wrote: »
    Not to pry...but what is your budget?
    If you really want to realize a step up from your AVR, perhaps you should consider a used but regarded integrated amp (which would have a better preamp section than your avr *and* have an amp section).
    A good external amp to your AVR would be a step up, but if you want to go one step beyond - gotta drive your speakers from a good source thru a good preamp/amp combination (separates or integrated).
    just my deflated 2cents worth....
  • Pycroft
    Pycroft Posts: 1,961
    edited July 2010
    I'm not sure just an amp will make that much of a difference. I think if you like music, you may want to just get an amp/preamp/CD player (or whatever source) and then you'll really hear what 2 channel can do.
    James
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • muncybob
    edited July 2010
    Ideal budget would be around $300 if I do this soon...maybe twice that if I wait until after this coming Christmas. I do most of my music listening in the winter so I would really like to make this step by October but it's not like my world will fall apart if I wait until January. I'm actually somewhat pleased with the way my music sounds now but the more reading I do the more it eats at me...just what am I missing?! But again, if all I can afford is an amp that may be approaching 10 years old don't I run the risk of needing the amp upgraded(caps, etc) to get the best I can out of the equipment?
    We do watch a lot of movies(reason I bought an avr) and I do like the avr second zone to avoid buying an amp, etc for the "game room".
  • Face
    Face Posts: 14,340
    edited July 2010
    What are you using as a source?
  • muncybob
    edited July 2010
    Face wrote: »
    Currently a Pioneer universal cd player....plan to soon get my old Denon tt into the shop to get back to vinyl though, which is part of the reason for a low budget(plus the wife thinks I have no budget at all!).
  • markmarc
    markmarc Posts: 2,309
    edited July 2010
    Wait until after Christmas if you can, then look for a used Musical Fidelity A3 integrated amp if you want to stay with solid state design. Plus, it has a quite decent phono stage.
    Former Staff Member TONEAudio
    2 Ch. System
