2009 F150 head unit install
domflane
domflane Posts: 653
Has anyone done a head unit replacement on the new F150's? Ive seen the double din installation kits online but I'm not sure how good it'll look compared to the stock unit. I want to get a double din screen to put in there, probably a Premier F90BT.
- Dominic
RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
Post edited by domflane on
  • exalted512
    exalted512 Posts: 10,734
    edited December 2009
    We haven't done any yet. I actually wasnt even aware they made a dash kit for them yet.
    -Cody
  • domflane
    domflane Posts: 653
    edited January 2010
    They make them, I'm just worried how it'll match the rest of the interior, I really want to do this install . . .
  • Phillips
    Phillips Posts: 40
    edited January 2010
    polkaudio | the speaker specialists
    Eclipse AVN6620
    Polk SR5250 (passive, 200w x 2)
    Polk SR104 DVC (series, 400w x 1)
    Earthquake 900w.5 (weak link - need upgrade)
    Rockford Fosgate Wiring & Accessories
  • domflane
    domflane Posts: 653
    edited January 2010
    A little, I've seen the kit on Ebay, $30 shipped. Its just that the interiors in the new F150s are really different and I don't know how the dash kit will blend in with the rest of the interior. I really want to add a double din DVD player, anyone here with a new F150 that can give some insight?
  • rdksek844
    rdksek844 Posts: 2
    edited July 2010
    I have whats called a magnelli marelli head unit. It is part of fords work solutions program. It has navi and is a double din, but is not the sync system. I hate it and I cannot add anything like sat radio nor a usb or aftermarket mp3 player. I want to buy a pioneer double din head unit, but crutchfield is clueless as to whether or not I need an install kit. I have searched the net relentlessly for an answer and no one has any clue. Does anyone here?
  • Installer4life
    Installer4life Posts: 256
    edited July 2010
    I will see if I can find the information for you on this. My friend bought a 2009 F150 with the woodgrain interior. We used a standard kit and he had it painted for about $100.00. It matched perfectly. I just can't remember where he had it done.
  • rdksek844
    rdksek844 Posts: 2
    edited July 2010
    I found a kit on ebay, but I just don't understand why I woudl have to change out my stock trim ring. I already have a double din opening with a touchscreen head unit in there. I don't get why I couldn't just swap it out with the new one.
