Specs for Monitor 5JR
starkiller
starkiller Posts: 2,723
edited July 2010 in Speakers
Anyone know the efficency of these or power handling capability?
thanks!
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
    edited July 2010
    Here's the guide info for the Monitor Series II line...probably close to these specs?
    In case you can't access the link below:
    Monitor 5jr Series II
    Drivers one SL2500 tweeter, 1 x 6 1/2 mid, 1 x 6 1/2" passive
    Overall Frequency response
    30Hz-25kHz
    46Hz-23kHz +/-3db
    20-125 watts....recommended power
    Impedance..compatible with 8 ohms
    Efficiency 90db
    cnh
  • starkiller
    edited July 2010
    Dang, too efficent....
    thanks for the info!
  • Bobsama
    Bobsama Posts: 526
    edited July 2010
    starkiller wrote: »
    Too efficient? For what?
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • starkiller
    edited July 2010
    Have a Luxman M-117 running a pair of Yamaha NS-200M's and thats way too much power for them, I don't have alot of wiggle room with the volume knob on my preamp. Plus, they take up too much room in my one car garage. So looking for a set of smaller bookshelf speakers that are say mid 80's in efficency. The Luxman has to stay so I have to deal with that....
  • Mannie
    Mannie Posts: 1
    Specs for the Monitor 5 jr
  • stevep
    stevep Posts: 359
    Those were specs for Monitor 5jr+ models. The "Plus" version replaced the port in the original Monitor 5jr with a passive radiator.
    I saved this from the forum and don't know who to thank for it.
  • skrol
    skrol Posts: 3,452
    If it was from this, I had created it several years ago. Maybe one of these days I'll continue it.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 51,799
    Damn Stan, quit your slacking ;)
  • skrol
    skrol Posts: 3,452
    :D
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • JB1962
    JB1962 Posts: 2
    I have a set of 5JR's and the vinyl is kind of sticky, like someone used a cleaning agent on them. Is there anything I can do to correct that or should I just leave it alone? They are just sticky enough to make them mildly stick to surfaces they are set on. So far it hasn't been a problem but I do wonder if at some point this could get to the point where the vinyl could peel from the cabinets. As on now I just use a folded dish towel underneath them
    F1nut Posts: 51,799
    Original Windex and soft cotton cloth.
