Laptop to Receiver - Wiring Question
kprhok
I just purchased a jack and wire to connect my laptop to my receiver which is positioned roughly 10 feet across the room. Is there any risk of losing sound quality due to the length of the wire from the laptop to the receiver? I know nothing about preamps and how sound gets from a laptop to a powered system, etc.
Thanks for advice on this. I would like to be able to sit in my recliner roughly 10 feet away from the system, and use the laptop to select music from ITunes.
Post edited by kprhok on
I do not see any issues having a cord that long.
Any quality you would lose, you have already lost by even putting your music on your computer (Unless it was in lossless format)
Anyway, you should be fine with a 10 ft cord....
If you wanted the best quality you could use optical....if your computer has a port for that.Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
Use a digital output if possible (probably mini to rca adapter). Try not to use a stereo mini to dual rca. The length of the cord probably will be the least of your problems.
Also, you can control your computer through an iphone or ipod touch if you've got it. This way you don't have to trail wires. -
Got it. Thanks for the feedback.
