bass in pirates of the carribbean
Airplay355
doc, whats goin on in this movie? im watchin it with my rti70's and the equalizer on my aiwa set on rock. sounds very nice, i like the bass alot and this is listening to it with 70's and on my aiwa. whats ur opinion on this?
Post edited by Airplay355 on
I don't have any waterfall charts for this movie. Pretty strong LFE with the cannon fights, etc. Nothing terribly out of the ordinary, though - maybe 30-40 Hz stuff.
The biggest LFE hit in the movie by far is when Capt. Jack Sparrow sees the gold medallion under water for the first time on the hottie and a huge shockwave rips across the sea. That RATTLED the room. I'd like to see a waterfall chart for that passage."What we do in life echoes in eternity"
SVS -
i know what ur talking about....the rti70's ignored that one lol but i knew it was supposed to be deep. is it comparable to the ring drop?
What a surprise. :rolleyes:
Ring Drop? Probably around the same frequency, but totally different in sonic signature. Like somebody touched off a nuke underwater."What we do in life echoes in eternity"
SVS -
The LFE track is not too heavy in POTC compared LOTR-TTT-EE & T3. I enjoyed the cannon shots though.
I recently watched LOTR-TT-EE on my new Yamaha RX-V1400 and I was totally blown away by the clarity of sound and deep bass. I recently bought Digital COAXIAL 3.3ft (Monster Interlink Datalink 100) cable. Very thick, 24k gold, solid cable. I still have to buy 2 rear channel speakers for 7.1 setup. Can't wait to watch in THX SURROUND EX all over again! and also DPLIIx for DPL movies in 7.1.
Digital Coaxial is far better than Optical cable. It makes the hell of a difference.
I LOVE COAX now! I used Optical for 3 years. Now, I truly believe in COAX.
All speakers set to small and X-over @ 80hz (THX Standard) the dream of jaw-dropping sound finally come true.
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player) -
I have that same cable feeding my Marantz SR5000 which in-turn feeds my Adcom Amps. I'm surprised you were able to tell a difference. I could not between that and a Monster Fiber Optic cable. They both sounded identical to my ears. I only went COAX for durability reasons.Digital Coaxial is far better than Optical cable. It makes the hell of a difference.
The bass in Pirates is decent and compliments the soundtrack nicely without being overpowering. Yes, the medallion sea drop is excellent. Several times during a neighborhood screening last Friday it got several WOW's during some bassy moments. It was great.
Peace Out~:DIf...
Ron loves a film = don't even rent. -
Man, that sequence made the eyes widen and the mouth open. Downright scary.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Try it with one of these in the loop. :cool:"What we do in life echoes in eternity"
SVS -
I could not agree more with all who posted on this topic especially Dr. Spec.
When that part happened I thought my ceiling was going to cave in. Money Talks, Mine says Goodbye Rob!!!! -
you can never have to much bass - I run two of these 18" bass horns
im going to go watch those parts on the M&K subwoofer. i recently got it back from the shop and its up and runnign again. its not even close to an impressive subwoofer or an accurate fast subwoofer but it digs deeper then my 70's and louder too lol.
Yes you can. When it overpowers the rest of the soundtrack.LSi 9/C/FX
Arcam AVR-200 -
Thanks for bringing that up Ron. I have not tried BOTH. But everyone that has CANNOT tell a difference. Especailly a night and day difference like hamzahsh is experiencing. Don't make me run out and buy another cable....lol I think DC is gaining alot of popularity recently not to mention earlier DD recievers did not even offer a DC input.Originally posted by Ron-P
Peace Out~:D -
Those horns are tasty. How about some specs & impressions?"What we do in life echoes in eternity"
SVS -
The drivers are McCauley 6174.
Voice Coil Diameter 100mm / 4"
Magnetic Coil Gap 0.4 / 10.1mm
Magnetic Assembly Weight 26 lbs / 11.8kgs
Flux Density 13,500 gauss
Bl Factor 15.3 T*m(8)
Moving Mass 0.222 kg
Fs Free Air Resonance 20 Hz
Re D.C. Coil Resistance 3.3(4) 5.6(8) ohms
Qts Total Quality Factor 0.340
Qms Mechanical Losses 2.900
Qes Electrical Losses 0.380
Vas Equivalent Vol of Air 25.9ft³
Sd Effective Piston Area 199 in³
Xmax Excursion - Max Bl 15.2 mm / 0.6"
Vd Sd x Xmax 200 in³
Le Inductance of V.C. 1.1 mH
%eff Mid Band Effeciency 0.66%
Pe Max Power Rating 800 W RMS sine wave
Overall Diameter 462 mm / 18.20
Overall Depth 254 mm / 10"
Bolt Circle Diameter 444 mm / 17.5
Baffle Cutout Diameter
Front Mount 425.4 mm / 16.75"
Rear Mount 419 mm / 16.5
Net Weight 16.3 kg / 36 lbs
The cabinets are BassMaxx B1
4 feet by 4 feet by 22 inches
What I like about horns is the type of bass you get. The sound if you will. It is not a punchy bass or a boomy bass. It's just fills the room, like air. It surrounds you but can still shake the foundation. I bought these after hearing them at a audio meet I went to at the designers house. -
Awesome! I bet the bass quality is a lot like an IB system.
I recently helped a friend build an IB with twin Stryke AV-15 and it sounds just how you described."What we do in life echoes in eternity"
SVS
