TSI400s or 500s
Any opinions out there on whether i should get TSI400s or 500s? I'm buying a PSW125 and not sure if i need the extra bass of the 500s. They will be used primarily for movies.
Post edited by nole06 on
For movies I'd say the 400s would be fine. That being said, for two-channel music I've heard the 500s and 400s together and there's no comparison: the 500s are significantly 'bigger and more detailed' speakers. I was unhappy with the lack of depth in the midrange of the 400s, but once again, that's for music. Stick with the 400s for HT and I think you'll be very happy, and you should definitely pair them with the CS20 center channel. Don't skimp on the center. Hope that helps!Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600 -
I had a pair of the 500's and was very satisfied with their sound in all respects.
I have 400's with a PSW505 and a center CS20. I use them mostly for TV/Movies and games (Rock Band). I am very happy with them, the PSW505 provides all the bass I'll ever need and compliments the 400's nicely.
I have not been able to turn the volume up more than 3/4 on my receiver because it gets so loud, in a good way.
Good luck. -
For movies, the 400's with a sub will probably do you fine. For music however, I think your best option would be the 500's.Fronts: Polk RTi A7's
Center: Polk CSi A6
Surrounds: Polk TSi500's
Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
Amplifier: Emotiva XPA-5
Processor/AVR: Emotiva UMC-1
DAC: Emotiva XDA-1
CD player:Emotiva ERC-1
Blu-Ray: Oppo BDP-93
Turntable: Kenwood KD-500
Tonearm: Polk-Mayware Formula 4
Cartridge: Shure M97-XE
Television: Sony KDL-55EX500
