Speaker Selection
KaosTsoc
KaosTsoc Posts: 372
I am looking at buying two 12" subs, and putting them into a ported box, and supplying at least the rms rating of the sub. I have narrowed my search down to a few options so far (not all are listed), and here they are:
Polk Audio SR124-DVC
Re Audio MX Series
Diamond Audio D612-12" dvc
JBL GTO1214D
So, my question is which one of these are going to be a good SQL, and SPL subs. I am looking to meet in the middle.
Note: I am still fairly new to the car Audio world, and any input would be nice. Also I am replacing my current after market system as well (Speakers only)
David.
2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Pioneer P860 Head Unit
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Kinetik HC2000 battery and Sleeve
200 Amp Mean Green High Output Alternator
Need a DJ, photobooth, or both for rent?
http://photoboothdallas.org
Post edited by KaosTsoc on
  • quadzilla
    quadzilla Posts: 1,543
    edited July 2010
    You might have more luck with this in the car audio section.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • jinjuku
    jinjuku Posts: 1,523
    edited July 2010
    Audioholics has a thread sticky on one heck of a high output, low distortion, value proposition sub woofer.
    It uses an infinity sub (~$150) plus a Behringer EP2500 or EP4000 amp and Behringer DCX cross over.
    Check it out: AH Kappa Sub Build
    Another option is DIYCABLE.Com
    Check out the Shiva-X2 or the Tempest X2. He has plenty of box options already documented for you to run with. While the drivers cost more you can run with plate amps and omit the external x-over and amp (but you also loose some headroom).
    I see you are using this for car audio. Still check out the drivers...
  • Amherst
    Amherst Posts: 695
    edited July 2010
    jinjuku wrote: »
    Is this what Audioholics members are using in their vehicles???
    Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
    Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
    Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU.
  • jinjuku
    edited July 2010
    Amherst wrote: »
    I am sure some are. The Infinity is a hard hitting, low distortion, and really affordable driver.
    F1nut Posts: 51,749
    edited July 2010
    amherst wrote: »
    is this what audioholics members are using in their vehicles???
    You're surprised!?!
  • jinjuku
    edited July 2010
    You're surprised!?!
    I am sure there are 1000's of people using those Infinity drivers in car applications. I mean if you know anything about audio in general and Infinitys sub offerings in particular they are known for their car audio products.
    Maybe if you had a little more education on the Kappa Perfect and what it's replacement driver measure at you wouldn't be caught unaware.
  • ohskigod
    ohskigod Posts: 6,505
    edited July 2010
    Infinity seems a bit of a fail to me,
    I will vouch for the Shiva though (I thought they went out of business though) I used a shiva for a home audio DIY sub and was pretty good, though i replaced it with a SVS 12" plus driver and it significantly outperformed it. prob overkill for a car.
    Behringer power amps? cmon man, really? we can do better than this (though not applicable for a car obviously) :p
    OP, head to the car section, very knowlegable folks there
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • jinjuku
    edited July 2010
    ohskigod wrote: »
    The Kappa Perfect VQ was a sub that was priced under what class it could hang at. Low distortion, high power handling, extremely linear. All around a really good sub considering the ~$170 price tag.
    Kevin Haskins has had a rough time making a go of a niche market. One especially when you want to offer a well engineered product at a reasonable price. But his 2nd go around seems to be working. He isn't playing the cut rate pricing game. Just turning out solid product.
    As far as Behringer is concerned my EP2500 has been doing sub duty for 3 years straight with zero issues. YMMV. Sometimes taking a chance pays off. I didn't want to spend any more than a I have to and 100's of people at AVSForum, AH, Hometheatershack so far have been proven correct. Proof is in the pudding.
    F1nut Posts: 51,749
    edited July 2010
    juju, you're still in the minors with no hope.
  • jinjuku
    edited July 2010
    Well I'm not sure what your sub setup is like but I would be willing to race for pink slips:rolleyes:;)
  • jinjuku
    edited July 2010
    Keiko wrote: »
    Grow up!
    Funny coming from the guy that has nothing to contribute. Don't start anything and there won't be anything kid.
  • jinjuku
    edited July 2010
    Trust me I need no reminders that this is the Polk Forum and unlike you I am welcome at other Audio forums.
    F1nut Posts: 51,749
    edited July 2010
    jinjuku wrote:
    Blah, blah, blah, blah
    Yawn
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2010
    +1 to creating a new thread in the Car Audio section.
    But may I ask, what's your budget Kaos for either the subs alone or sub+amp? Or do you already have an amp at hand?
    Can't even imagine what juku's saying now, that kid's been on my ignore list since I came back to the forum.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • KaosTsoc
    KaosTsoc Posts: 372
    edited July 2010
    Sorry guys for not checking this thread in while. My bad. Also I do know that I had put this in the wrong section as well..... Yeah Im smart sometimes.
    kawizx9r
    My budget for everything (subs, comp's amps, wiring, Dynamat, HO Alt) is roughly $3,200 give or take. I am saving the money now for the subs, comp's amp, and HO Alt, so this is something that is going to take a little, but I have great resolve. Here is a run down of where this is all going into
    2006 Toyota Tacoma Access cab
    Plan on being a ported box, and have everything set to manuf. specs as far a freq goes etc.
    Note: As for all the other people on here arguing about something that is not even relevent to my question. please stop. If you are looking to have an argument, please take it somewhere else or leave to P.M. only. I really dont like reading a bunch of grown a** men acting like "kids" trying to have a pissing contest. So, get a grip, and grow up. Thats all Im going to say about that.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  • KaosTsoc
    KaosTsoc Posts: 372
    edited July 2010
    Keiko,
    Thanks I will look him up, and see what he has to say.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
