2 center speakers
We are considering moving our TV to a different wall. Positioning, we can't put the speaker under the TV, and putting it over will get very high. However, we could easily position 2 speakers to the left and right of the TV. (Almost as if the TV's speakers were mouted on the left and right of the screen instead of under the screen).
Basically, we would sit about 15' back from the TV. The L/R mains would be 15' apart. With this configuration, the "L/R Center Speakers" would be about 45" apart.
Anyone else use 2 center speakers like this? Power is coming from multichannel amp, so powering the set-up is not an issue.
Post edited by polktiger on
Which center channels do you plan on using? If you plan on orienting the center channels vertically, I've tried it with a CSi5 and it ruined the imaging.My System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun -
Wow. 15' away from the TV. Is it a 100" projector? I have a 57" and I am 8-9 feet back, and that is about right for a big screen experience.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
We would be using regular L/R speakers, probably inwalls. If it was a center it would be one that can be mounted vertically. In all likelihood I will get totems for this system.
TV is "only" 46." Any bigger and we really feel like the TV starts to overpower the room which is not a dedicated HT.
