urgent
scottyboy76
adcom gfa 535 with static issues in volume control knobis available with gfa 400 preamp klipsch 10 in. woofer and infinity bookshelves for 100 clams. does the static issue sound like somethin tough to fix, also would the pre be worth that alone.
humpty dumpty was pushed
Post edited by scottyboy76 on
Difficult to actually say, but if the static is occuring as the volume is activly being changed cleaning the volume control with DeOxit could eliminate the problem. The problem would actually be in the Adcom gfa 400 since it is the preamp with the volume attenuator. The entire package for 100.00 ?integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
That adcom pre...is not one of the preferred Adcom pres...(GFP-715 or GFP-750) so depends on if the bookshelves and sub are OK.....
Doctor R may be VERY right, though,...get some DeOx...and have at the pre control knobs, etc.
the 535 for 100 bucks is a decent price--dual mono--powerful little puppy tooJC approves....he told me so. (F-1 nut)
Good point GD...do you have something ELSE you could plug the Adcom GFA-535 into..that's definitely worth a 100 if it's working properly...the pre...probably needs some Deoxit or a bit of professional attention. But if the amp is OK you're good.
i still have yet to hear from the person selling, but in the ad everything else i supposed to be fine. thanks for advice. if volume knob is defective, is it something that can be replaced, or fixed.humpty dumpty was pushed
If man made it, it can be fixed.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
+1,
A very simple fix for any Tech!
adcom gfa 400 volume knob static, if it is beyond deoxit, is this something that is available for replacement or repair. i could get it cheap so it could be worth it.humpty dumpty was pushed
i posted again before seeing the last two replys thank you. i have always wanted separates but budget on fixed income, you know. i think when the seller responds i will pull the trigger, keep your fingers crossed for me please. the ad was placed yesterday so maybe its still available. god bless our troops. if i get this gear i will be donating my yammy receiver to the vfw for a returning combat troop who would like a home theater, maybe some excess speakers too. not much but it could be a big deal to someone who has given so much to us.humpty dumpty was pushed
i have seen signal processors i think from carver on cl, would that be a good way to have surround with separates instead of treceivers or does it work that way.just wonderinghumpty dumpty was pushed
if the adcom you are speaking of is in Atlanta--I'd contact the seller and get on over there,,the amp is worth the 100 bucks--good luck--let us know how it turns out.JC approves....he told me so. (F-1 nut)
i will do that, in fact you wont be able to shut me up, i know this is not a big deal to many, but i never thought i could afford, thanks guys. im not getting too excited these things hardly ever work out for me, but you never know.humpty dumpty was pushed
