Cartridge suggestions
cstmar01
cstmar01 Posts: 4,424
edited July 2010 in 2 Channel Audio
Looking to possibly upgrade my cartridge in the future, just have no idea where to start. Current one I'm using is what came with my table a music Hall 2.2LE and it is the Music Hall Tracker. I like the sound, enjoy it, just would like to have an idea of what I would be looking at for an upgrade.
Seeing I've never set one up (mine can set up from the get go) I would want something that wouldn't require hours upon hours of tweaking to get right. Also I would say nothing over 150.00 for a price.
Post edited by cstmar01 on
    nooshinjohn Posts: 25,917
    edited July 2010
    Denon DL-160... Great cartridge for the money.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2010
    +1.
    Got this one. Great sound for the price!
  • audiobilly
    audiobilly Posts: 351
    edited July 2010
    +1
    Check this out as well,
    http://www.mofi.com/store/pc/viewPrd.asp?idproduct=20&idcategory=11
  • PSOVLSK
    PSOVLSK Posts: 5,380
    edited July 2010
    cstmar01 wrote: »
    Agree with the Denon recommendation, but can one be had for $150? Currently $180 at Amazon.
    edited July 2010
  • PSOVLSK
    edited July 2010
  • schwarcw
    schwarcw Posts: 7,358
    edited July 2010
    Greetings Chris!
    I own the DL-160 and it is a great cartridge. It is a low output MC. Make sure that your phono preamp has a gainof about 45 dB or more. Another good choice is the Audio Technica 440 MLa. This MM cartridge has much more gain than the Denon. Good luck!
    Carl
  • cstmar01
    edited July 2010
    schwarcw wrote: »
    Greetings Chris!
    Thanks for the info Carl. I totally forgot about MC vs MM. Currently I have a MM so what would be the benefits of running a MC? Does one normally obtain better sound quality?
    and thanks for the link John, I'll look into it!
  • schwarcw
    edited July 2010
    Chris,
    The MC may sound quieter, less surface noise, beter IMHO.;)
    What type of phono preamp and preamp do you have?
    Carl
    Carl
  • quadzilla
    quadzilla Posts: 1,543
    edited July 2010
    The main benefit of a MC cart over a MM is that the cantilever has less mass on the back end, and so is able to present a more accurate play back. As the name states, MC carts have the coils mounted on the back end of the cantilever where the MM carts have the magnets mounted there. There are some very fine MM carts out there, but the best MM won't compare to the best MC. You can also find high output MC carts which are built to be compatible with MM phono stages. My personal preference the Shelter line, though Van Den Hul and a couple of others have my interest should I ever get the money to play.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • audiobilly
    edited July 2010
    FWIW,
    The Dennon DL-160 is a high output MC cart.
    http://www.usa.denon.com/ProductDetails/539.asp
    I can be used in a MM cart setup. Another plus for this cart.
    schwarcw wrote: »
    Greetings Chris!
  • hearingimpared
    hearingimpared Posts: 21,136
    edited July 2010
    quadzilla wrote: »
    As a lover of high end MC carts I have to disagree with only the bolded section of you post above. I've heard some high end MMs that are just spectacular but I'm still sticking to very low output MC carts as they just are so transparent and really bring out the inner detail, decay & bloom etc.
    Chris based on your budget, I would day the Denon DL-160 is a good bet. If however you find yourself with more cash try the Dynavector 10 X 5.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2010
    Check out Grado laboratories
    many original patents on cartridge design were first innovated by this USA company.
    http://www.gradolabs.com/frameset_main.htm
