DIY Line Array Project
setzer808
Hey gang,
Decided I would post the results of my DIY Line Array towers I built. This was just a summer project for the heck of it, and i'm very pleased at how they turned out. They use the JVC 3x5's that were recently on clearance at Parts Express. The housing is vinyl fencepost and caps. I'll let the pictures make things clearer. The sound is surprisingly good and produces a very lively/large soundstage on music. Currently I have them wired at 16ohm's each to fit the needs of an older amp for home use, but I did wire them at 4'ohm's each and ran them off a PA amp to test them in an auditorium vs a pair of Bose line arrays. Their throw is impressive. I like my results...especially considering the total cost for all the materials of the pair was under $50 or so.
Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
Polk PSW-350 Sub -in storage.
Yamaha RX-V681 A/V Reciever
Sony SCD-CE595 SACD Player
Polk RT55i Mains
Polk RT25i Rears
Post edited by setzer808 on
Pics are not visableSpeakers: SDA-1C (most all the goodies)
Those are pretty sweet looking and the price is right on.
Do they have an kind of filter, or are you running them sans crossover? -
Thanks. As I still consider them a work in progress they are running fullrange with no crossover or notch filters or anything at the moment. I may do some more tinkering on that front in the future when my next projects are done. Though I do have a spare EQ I might use with them as well come to think of it...Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
Sony SCD-CE595 SACD Player -
Thanks for sharing!
That is totally badass and weird at the same time. I hope you had fun making the speaker cutouts....
It looks like the speaker terminal is a 1/4" plug. I wonder why? Are you gonna use them as guitar speakers? -
Spiffy! Nice job and the price is so right :cool:DARE TO SOAR:
Thx again, ya it is a 1/4" jack. I first hooked them up to a powered mixer when I was testing them in the auditorium and did that for convenience there. Since I had a pair of old cables that were 1/4" to bare wire available for the home setting lying around, it ended up working in both places. I've had some friends/co-workers asking me to build them a set, in those cases I would use a standard binding post plate.Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
audiobilly wrote: »
Don't tempt me....I've already had visions of adding a smaller spire containing a tweeter array (not that the extra highs are really necessary) beside each of those...and mounting the spires on a multi-driver sub stack.
Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
Can someone point me in the direction or tell me why line array is cool, other than the looks?
I'm halfway interested in building something like this, but would like to have more justification to the SO other than "But it LOOKS bitchin'!!!"I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Can someone point me in the direction or tell me why line array is cool, other than the looks?
http://techtalk.parts-express.com/showthread.php?t=218570"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Thanks... that's pretty interesting, though i'm now unsure if that's what i'm looking for.
Basically a line array works by exploiting the interaction of multiple drivers...the gain from that many
same-purpose drivers outweighs most of the negative interactions involved so that the larger your array...the more benefit you get in the areas of long throw distance, power handling, etc. Also line arrays have some benefits when it comes to lower microphone feedback...which I have witnessed....but don't have a firm enough knowledge to speak much on.Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
Now if these could be made waterproof, just think of the potential for outdoor speakers.
woofiepaws wrote: »Now if these could be made waterproof, just think of the potential for outdoor speakers.
Oh I know...I've been wishing I could find a good supply of cheap, full-range drivers like the JVC's that were weather-resistant...Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
Am I missing something? Where are the tweeters?Fronts: DIY Statements from htguide.com
Center: DIY custom Statement center from htguide.com
Surrounds: Four DIY custom Mini Statements
Wire: HD-14
Receiver: Denon AVR-4806 + CI upgrade
Amps: Dual Emotiva LPA-1's
Sub: Infinite Baffle: 8 fiCarAudio IB315 woofers, Behringer DSP1124P EQ, Elemental Designs eQ.2, Dual EP4000 amps
Transducers: 2 buttkicker LFE's, BK amp, EQ'd w/DSP1124p
DVD: Toshiba HD-XA2 / PS3
TV: Samsung 1080p 61" DLP -
The 3x5's are full range drivers that sufficiently cover the high frequencies.Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
I went to PE's site to look for specs but couldn't find them.. what model are they? I think your speakers look cool, just curious
Wire: HD-14
This here project surely must fit in the things guys do catagory!
Great job and ingenuity also!
You could always just bring them outside when you barbeque and ad a sub with the outputs to handle the lows. I want to start my own set as soon as it gets cooler weather down here.
Cool.Most people just listen to music and watch movies. I EXPERIENCE them.
I wonder what these sound like:
They are from a demo room at the Grado headquarters
Apparently they each have 32 headphone drivers. Can someone explain how this would work? How can these sound good from far distances? -
I seriously doubt that~TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I used the term "sufficiently" deliberately.....the 3x5's have a lot better high end than many full-range drivers I've encountered...but I would still say they only handle the high end "sufficiently"....not exceptionally or excellently. Kind of like how you could live on MRE's and water....all the technical requirements for survival are met...but its not lobster and Dom PPolk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
@frodady: They were a buyout item at PE from JVC. I think they sold out about a week ago. If they ever get any more in and you order them...order at least 20...that way they come in a nice plastic-spaced packaging that protects them...otherwise they are wrapped in cardboard and may suffer a bit in transit.Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
Coolest thing I've seen all week.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
