Best blu-ray player as transport
EFanning
Let's say I planned to buy a DAC like the Musical Fidelity V-DAC and pair it with a blu-ray player for two channel CD listening.
The goal here would be to avoid redundancy: If a blu ray player is sending digital output to a V-DAC that matches a CD player, why have two players?
So, what blu ray player should I buy? Or, to get better two-channel sound, should I match the V-DAC to a decent CD player?
The blu-ray player would be purchased to improve picture quality in movies. I would never used the HDMI audio out for true 7.1 sound.
Marantz DV4001 CD and DVD
WD TV Live Hub with 1 TB (Need DacMagic)
Marantz PM7001 Integrated amplifier
Philips GA 312 Turntable
Polk Monitor 70s (Zone 1)
Polk Monitor 40s (Zone 2)
Post edited by EFanning on
Since the V DAC incorporates a sample rate converter it is less susceptible to jitter in the transport-dac interface.IMO therefore it makes the choice of transport less of a variable.
Well, I guess the issue is what CD player vs the bluray/V-DAC combo?
I thought the same thing and popped for a Bel Canto DAC-2 to match up to my Oppo BDP-83 thinking it would crush my Cambridge 640c V2 CDP for 2-channel. And I would get rid of the CDP.
I paid $675 for the Bel Canto DAC-2 off of audiogon (it sold for about $1200 new).
I paid $369 for my Cambridge 640c V2 CDP (list price was something like $679).
The Cambridge 'beat' the Oppo/Bel-Canto combo in my rig. I just didn't like the sound presentation of the Bel-Canto - the soundstage was too narrow - almost sounded like listening in mono all the time.
I would say that the answer to your question is component dependent.
Just my deflated 2cents worth....
Going OT here so my apologies.
Erik - Which -83 do you have? I thought you bought an SE?-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Nope - just the vanilla flavored 83.
I was debating whether to upgrade my 83 or buy a 'killer' DAC so I could get rid of my CDP.
The 'killer' DAC didn't work out as I expected
I'd like to get my ears on a 83SE.
While I've read glowing reviews of the 2-channel sound of the 83SE, I've also seen indications that it still won't 'beat' a dedicated high quality CDP.
I'd like to hear the 640, it's a "CD only" player right?
I'm on record as loving my SE for 2ch analog. I think you might be pleasantly surprised by what a SE or NE upgrade would get you.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
Yes the 640 is a CDP only, but it uses dual Wolfson DACs - all the rage...
It has a detailed sound to it - very spacious soundstage. Some would call it 'analytic'. I've compared it to the DACs in my AVR and in the standard Oppo83 - which I would characterize as unremarkable - not bad, but a bit dull for my tastes.
I like the notion of a do it all player -but not sure if it would be worth the coin to buy a Modwright 83SE to go up the SQ ladder for 2-Channel sound. For that amount of money I could get a really nice used CDP on the 'gon.
The Sabre DACs in the SE are a different animal then the Cirrus DACs in the 83. It's a significant upgrade. Well worth the money in my opinion. YMMV.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
I know, but for $1300 I can get a 'killer' CDP on the 'gon.
I'm all about 'hop ups' - been there done that with my dirt bike.
I started with a Honda XR250 enduro but soon wanted it to be a motocross bike. I had the trickest XR, bored to 280cc, ports polished, 3-angle valve grind, aftermarket header & exhaust, upside down forks, custom shock, aftermarket handlebars, sprockets and chain.
Killer....but it never was a motocross bike - still an enduro.
That's kinda how I see the Oppo83 - an 'enduro' of players - but no matter how much you 'hop it up' - its still an 'enduro'.
Like I said - would love to hear one first hand.
Erik.
Were you able to run the cambridge into the Bel Canto via digital out.?
Or was it just the sound of the canto you didnt like.?I was considering buying one for its 24/192 upsampling.Now, maybe not.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Erik.
Yes, I did that test too - had the Cambridge hooked up via analog to my rig and digital coax to the Bel Canto, then analog out from the Bel Canto to my rig at the same time.
I switched back and forth and preferred the Cambridge DACs - the Bel Canto had a 'signature sound' whether connected to the Cambridge or the Oppo - so there was no transport difference.
The Wyred4S DACs are getting rave reviews - could try that after a bit when they start showing up on audiogon for a lower price.
They use the new Sabre DACs as well.
Oh yes Ive been taking a herd look at the WFS II as well.A little to costly new.But if a good deal pops on the gon Im there too.SDA-2BTL with custom IC
I own the Denon 3800BDCI blu ray player. It is phenominal as a player. It has phenominal video playback, and audio via the analog outs cannot be beat. As a transport, it has great a great laser mechanism, but one down side is that it can be slow at reading discs. The player does take a little patience. I know many people talk about the Oppo (which I have not seen or heard) but it seems hard to believe the Oppo can beat this Denon. Being as it is a phased out player, it can be had relatively cheap now (under $600.00). I recommend you take a look and listen to it.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Consider ripping your CDs then streaming the audio either to a squeezebox or directly to your receiver. The device that you stream to will need a good DAC, however.
Personally I rip with dbPoweramp in WAV format, and stream with Windows Media Player directly to my Denon 4806CI receiver. Out of my Toshiba HD-XA2 and the PS3, streaming the audio is by far the best 2ch playback with my current equipment.Fronts: DIY Statements from htguide.com
Center: DIY custom Statement center from htguide.com
Surrounds: Four DIY custom Mini Statements
Wire: HD-14
Receiver: Denon AVR-4806 + CI upgrade
Amps: Dual Emotiva LPA-1's
Sub: Infinite Baffle: 8 fiCarAudio IB315 woofers, Behringer DSP1124P EQ, Elemental Designs eQ.2, Dual EP4000 amps
Transducers: 2 buttkicker LFE's, BK amp, EQ'd w/DSP1124p
DVD: Toshiba HD-XA2 / PS3
TV: Samsung 1080p 61" DLP -
The blu-ray player would be purchased to improve picture quality in movies and also you can transfer movies in DVD and also CD. Blu-ray has best converter for movies.Genius is an immense capacity for taking trouble
Greg
You nailed it. I recently sold my Denon 3800 and bought and Oppo instead, largely because off the insanely slow "reading" time of the Denon. The Oppo is massively quicker.
Of the two plavers the Denon in my opinion had superior audio performance and I would also say better video performance as well, although the Oppo is much closer in video.
I sold my Denon for $ 500 -
my Oppo NE is blowing my mindOnkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
