Best blu-ray player as transport
EFanning
EFanning Posts: 60
edited July 2010 in 2 Channel Audio
Let's say I planned to buy a DAC like the Musical Fidelity V-DAC and pair it with a blu-ray player for two channel CD listening.
The goal here would be to avoid redundancy: If a blu ray player is sending digital output to a V-DAC that matches a CD player, why have two players?
So, what blu ray player should I buy? Or, to get better two-channel sound, should I match the V-DAC to a decent CD player?
The blu-ray player would be purchased to improve picture quality in movies. I would never used the HDMI audio out for true 7.1 sound.
Marantz DV4001 CD and DVD
WD TV Live Hub with 1 TB (Need DacMagic)
Marantz PM7001 Integrated amplifier
Philips GA 312 Turntable
Polk Monitor 70s (Zone 1)
Polk Monitor 40s (Zone 2)
Post edited by EFanning on
  • FTGV
    FTGV Posts: 3,650
    edited July 2010
    Since the V DAC incorporates a sample rate converter it is less susceptible to jitter in the transport-dac interface.IMO therefore it makes the choice of transport less of a variable.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2010
    EFanning wrote: »
    Well, I guess the issue is what CD player vs the bluray/V-DAC combo?
    I thought the same thing and popped for a Bel Canto DAC-2 to match up to my Oppo BDP-83 thinking it would crush my Cambridge 640c V2 CDP for 2-channel. And I would get rid of the CDP.
    I paid $675 for the Bel Canto DAC-2 off of audiogon (it sold for about $1200 new).
    I paid $369 for my Cambridge 640c V2 CDP (list price was something like $679).
    The Cambridge 'beat' the Oppo/Bel-Canto combo in my rig. I just didn't like the sound presentation of the Bel-Canto - the soundstage was too narrow - almost sounded like listening in mono all the time.
    I would say that the answer to your question is component dependent.
    Just my deflated 2cents worth....
  • vc69
    vc69 Posts: 2,500
    edited July 2010
    Going OT here so my apologies.
    Erik - Which -83 do you have? I thought you bought an SE?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Erik Tracy
    edited July 2010
    vc69 wrote: »
    Nope - just the vanilla flavored 83.
    I was debating whether to upgrade my 83 or buy a 'killer' DAC so I could get rid of my CDP.
    The 'killer' DAC didn't work out as I expected :(
    I'd like to get my ears on a 83SE.
    While I've read glowing reviews of the 2-channel sound of the 83SE, I've also seen indications that it still won't 'beat' a dedicated high quality CDP.
  • vc69
    vc69 Posts: 2,500
    edited July 2010
    I'd like to hear the 640, it's a "CD only" player right?
    I'm on record as loving my SE for 2ch analog. I think you might be pleasantly surprised by what a SE or NE upgrade would get you.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Erik Tracy
    edited July 2010
    vc69 wrote: »
    Yes the 640 is a CDP only, but it uses dual Wolfson DACs - all the rage... :D
    It has a detailed sound to it - very spacious soundstage. Some would call it 'analytic'. I've compared it to the DACs in my AVR and in the standard Oppo83 - which I would characterize as unremarkable - not bad, but a bit dull for my tastes.
    I like the notion of a do it all player -but not sure if it would be worth the coin to buy a Modwright 83SE to go up the SQ ladder for 2-Channel sound. For that amount of money I could get a really nice used CDP on the 'gon.
  • vc69
    vc69 Posts: 2,500
    edited July 2010
    The Sabre DACs in the SE are a different animal then the Cirrus DACs in the 83. It's a significant upgrade. Well worth the money in my opinion. YMMV.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Erik Tracy
    edited July 2010
    vc69 wrote: »
    I know, but for $1300 I can get a 'killer' CDP on the 'gon.
    I'm all about 'hop ups' - been there done that with my dirt bike.
    I started with a Honda XR250 enduro but soon wanted it to be a motocross bike. I had the trickest XR, bored to 280cc, ports polished, 3-angle valve grind, aftermarket header & exhaust, upside down forks, custom shock, aftermarket handlebars, sprockets and chain.
    Killer....but it never was a motocross bike - still an enduro.
    That's kinda how I see the Oppo83 - an 'enduro' of players - but no matter how much you 'hop it up' - its still an 'enduro'. ;)
    Like I said - would love to hear one first hand.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Erik.
    Were you able to run the cambridge into the Bel Canto via digital out.?
    Or was it just the sound of the canto you didnt like.?I was considering buying one for its 24/192 upsampling.Now, maybe not.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • Erik Tracy
    edited July 2010
    fbm211 wrote: »
    Erik.
    Yes, I did that test too - had the Cambridge hooked up via analog to my rig and digital coax to the Bel Canto, then analog out from the Bel Canto to my rig at the same time.
    I switched back and forth and preferred the Cambridge DACs - the Bel Canto had a 'signature sound' whether connected to the Cambridge or the Oppo - so there was no transport difference.
    The Wyred4S DACs are getting rave reviews - could try that after a bit when they start showing up on audiogon for a lower price.
    They use the new Sabre DACs as well.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Oh yes Ive been taking a herd look at the WFS II as well.A little to costly new.But if a good deal pops on the gon Im there too.
  • headrott
    headrott Posts: 5,496
    edited July 2010
    I own the Denon 3800BDCI blu ray player. It is phenominal as a player. It has phenominal video playback, and audio via the analog outs cannot be beat. As a transport, it has great a great laser mechanism, but one down side is that it can be slow at reading discs. The player does take a little patience. I know many people talk about the Oppo (which I have not seen or heard) but it seems hard to believe the Oppo can beat this Denon. Being as it is a phased out player, it can be had relatively cheap now (under $600.00). I recommend you take a look and listen to it.
    Greg
  • frodaddy
    frodaddy Posts: 124
    edited July 2010
    Consider ripping your CDs then streaming the audio either to a squeezebox or directly to your receiver. The device that you stream to will need a good DAC, however.
    Personally I rip with dbPoweramp in WAV format, and stream with Windows Media Player directly to my Denon 4806CI receiver. Out of my Toshiba HD-XA2 and the PS3, streaming the audio is by far the best 2ch playback with my current equipment.
    Fronts: DIY Statements from htguide.com
    Center: DIY custom Statement center from htguide.com
    Surrounds: Four DIY custom Mini Statements
    Wire: HD-14
    Receiver: Denon AVR-4806 + CI upgrade
    Amps: Dual Emotiva LPA-1's
    Sub: Infinite Baffle: 8 fiCarAudio IB315 woofers, Behringer DSP1124P EQ, Elemental Designs eQ.2, Dual EP4000 amps
    Transducers: 2 buttkicker LFE's, BK amp, EQ'd w/DSP1124p
    DVD: Toshiba HD-XA2 / PS3
    TV: Samsung 1080p 61" DLP
  • addiewillium
    addiewillium Posts: 4
    edited July 2010
    The blu-ray player would be purchased to improve picture quality in movies and also you can transfer movies in DVD and also CD. Blu-ray has best converter for movies.
    Genius is an immense capacity for taking trouble
  • lakesailor
    lakesailor Posts: 319
    edited July 2010
    headrott wrote: »
    Greg
    You nailed it. I recently sold my Denon 3800 and bought and Oppo instead, largely because off the insanely slow "reading" time of the Denon. The Oppo is massively quicker.
    Of the two plavers the Denon in my opinion had superior audio performance and I would also say better video performance as well, although the Oppo is much closer in video.
    I sold my Denon for $ 500
  • jayman_1975
    jayman_1975 Posts: 672
    edited July 2010
    my Oppo NE is blowing my mind
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
