SR to MM :( conversion.....
brettw22
So over the past several months my SR's have each started to crackle and get to the point that I cannot listen to them pleasantly singing away due to the degradation of sound........
Since the SR's are wiped out and gone (as is the entire warranty stock), I've decided that I'm going to put the MM6501's in their place (I have 2 sets of SRs, thus 2 sets of MMs will be installed). I'm hoping that it'll be a fairly simple swap since the drivers are all the same size........(pipedream i'm sure)
I know the crossover of the SR was well designed, but would it make any sense to keep that being used with the MM drivers? Is that even an option?
Post edited by brettw22 on
Ummm...I think the MM series magnets are larger. Better check that.
As far as the SR crossovers being used, you may need to do a bunch of tuning/tweaking but you could most likely use them with the MM speakers.Expert Moron Extraordinaire
It should be relatively easy. The SR basket was shallow but pretty damn wide so the MM's should just drop right in.
As for the crossover, the SR crossover is pretty high. It has the tweeter cut off a lot higher than the silk MM tweeter will be. It actually might work out cause Ive always liked a higher cutoff point for my tweeters anyway. You can always hook them up and see how they sound. Wont hurt anything other than being a pain in the **** to unhook em if they dont sound good.polkaudio sound quality competitor since 2005
I too had to down grade from the sr's to the momos recently. The sr's had cleaner and more natural upper mids and better mid bass in the 40-70hz range. More dynamic and better transients. But heck, the momos are almost 80% there. It's the last 20 % you miss. The MM's are better than the momos. Both at the bottom and top. So you're probably looking at a difference of about 15%.
If its the sr mids that are messed up and you're running passive, try running the MM mids with the sr tweets thru the sr xover. Oh! and try running just one pair upfront first. You really don't need the second pair. Just a thought. -
The sr 5250 is still available. It's a 5.25" mid driver. The sr-6500 are all gone. These were a 6.75" driver.
Polk is not replacing them with something else?
I'm hoping they will. I'll know next week.
Yeah, but shipping to India would be a killer...:) Plus, 99% of the people selling car audio equipment would have pushed it past the safe levels. Maybe its just a mindset. -
touche
what happened Brett, too much abuse or what, why are they all failing?Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Initially it was the front driver-side speaker that started to have some static/buzzing issues......then somehow over the next few weeks (while the car was sitting at the airport) they started to all bring a static/buzzing sound to some of the stuff I was listening to.
I don't listen to them crazy loud....i've had moments, but I'm not one to have things blasting to the point of being heard 5 miles down the road........
The reason the SR line was discontinued was the manufacturer that was making the parts went away (i think bankrupt). From Polks perspective, they would ultimately have to completely start a new line bottom to top to get it back up and running since the components would be different etc etc so they opted to not invest into the R&D of another bottom up line......comment comment comment comment. bitchy. -
hey why not look on Epay for some replacement SR drivers or the parts you need?PolkFest 2012, who's going>?
for replacement parts, unless they're coming from a manufacturer I'm generally gonna err on the side of people selling junk that I don't want to have to bother with as an option....
I've read that the MMs are really well made speakers, so I'll give them a go and see what happpens......comment comment comment comment. bitchy. -
That's really disappointing to hear that the SR drivers are, well, failing. Really makes me wonder about some wiring issues or shorts that could have damaged them, or some noise that's being induced from a new scenario, or worn interconnects or something to introduce this static.
I just don't want to accept that the SR's had a terribly short lifespan.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
When the company that's making them for you goes under, Polks hand are tied.....comment comment comment comment. bitchy.
I think pulling the SR series, was purely a commercial decision taken by DEI/Polk. IIRC when Polk selected this factory in China to make the SR drivers, they were already doing business with this factory. I don't think any of the home audio side speakers have been pulled on this account.
Plus, when selecting the factory to make the SR's, at least 2 other factories were put through the grind. Factory visits, compliances, sample batch approvals, etc etc. So if the current factory was going under, there was a back up. -
I have a really good feeling that if Matt Polk still owned the joint, the SR's would still be going.
DEI is a huge **** company and they know theres a lot more money to be made in selling $100 subs to teenagers by the droves as opposed to selling a few $900 sets of speakers to the relatively few audiophiles.
Thats why there are virtually no audiophile level car audio speakers left! All the smaller, SQ oriented companies were bought out by big massive companies and out go the high end and in come the $100 subs with blue LED's on them.
Thats probably why the top SQ guys use raw home audio drivers in their rides as opposed to off the shelf stuff.polkaudio sound quality competitor since 2005
That's a damn shame. I was just lately extolling the virtues of the SR line. Shoot, I wanted to get some for myself... Damn...
Antny, You can still find the 5-1/4" models
Not really. I was told there were like a dozen sets left and that was several months ago. Im sure there are still some floating around out there but they probably wont be in authorized dealers.polkaudio sound quality competitor since 2005
Yeah, but you don't need 2 pairs. So $600 would do it. A 4k car with sound worth a million bucks would be a cool ride
When I'm listening to the music, all the flaws in my 9K (book value) Ford just vanish
The 6x9 and the components would sound different. The 6x9 though would munch on the compos for bass and loudness. If you can get them in the front doors, that would be great. Don't run a second pair as rears
