Please help with my IR setup.....
K-daugh
K-daugh Posts: 467
ok just picked up an hk avr 247(three weeks old) so far i am very pleased with hk....sound quality is amazing...im sill working all the bugs out and getting to know all the new formats....(my old receiver was ten years old)....but i currently have my receiver,dvd player and comcast(motorola)hd dvr box......in the closet....i just purchased a dual frequency ir receiver and a dual head ir emitter.....the ir receiver i have plugged into the remote ir input and the emitter i have plugged into the remote ir output....each one of the emitters are stuck on the neccesary components.....its not working!!!!!!!what am i doing wrong ....is the avr able to be considered the power source needed for the receiver ....or do i need to add an ir repeater/extender(control box).......also is it possible to run a motorola hd dvr box from an hk remote .....the code isnt in the manual........did i mention i love this receiver:D:Dplease help guys:)
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers
Post edited by K-daugh on
  • K-daugh
    K-daugh Posts: 467
    edited July 2010
    why isnt the avr my power source for the ir receiver.......what kind of ir receiver does hk want you to use????
    Custom Jumpers
  • bikezappa
    bikezappa Posts: 2,463
    edited July 2010
    I use the old RS reciever and transmitter, they look like small pyrimids, to operate all my equipment in the closet. Are you using a wired system? I tried a wired system from Parts Express and it didn't work that well. The only issues with the RS system is you need to play with positions. I have 4 transmitters in various locations and only one reciever in the closet that operates all 4 components fine. I can operate the system from the 4 locations.
