OWM3 as "bookshelf"???
fkorbel
hello, i may need your help. can i use OWM3 as regular speakers without subwoofer? is there a special frequency switch needed as by BOSE cubes? thanks to everyone for advice!
Post edited by fkorbel on
First, welcome to Club Polk! Now, to answer your questions:
Yes, no, and there are too many options out there to even bother doing so, unless maybe they're for a lo-fi environment, such as an outdoor patio. -
Yes you can use the OWM's as bookshelf speakers. While they will sound better with a sub it is not required. There is not a switch or anything on the speakers. Just hook them up to either a stereo or home theater amplifier and you are good to go.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Are you looking at a used set? If you are looking new, a pair of Polk Monitor 30's will likely be a better bet for small bookshelves. But yes, the OWM3's can very well be used as a bookshelf speaker and would require no sub to work. Just a amplifier or receiver and some speaker wire.- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC
