Surround Repair
I have a pair of JBL L3's that I picked up on Craigslist for $100 to mess around with. I enjoyed them for 2 days when I noticed a weird sound coming from one of the 8" woofers. The surround started coming off at the bottom left.
I was curious if I could get an opinion as far as possibly super gluing it back on (i.e. what to use; should I order something speaker-specific or am I able to go to the hardware store) ?
Is there a pretty high chance of it happening again ?
All opinions are greatly appreciated.
Thanks!
Brandon
Thanks!
Brandon
Music [2.2]
Speakers: polkaudio RTi12
Future Speakers: DIY Fusion-15 Sentinel's
Subwoofer: DIY Dual LAB15's
Subwoofer Amp: Behringer iNUKE NU6000DSP
Preamp: Emotiva XSP-1
Amp: Emotiva XPA-2
CD Player: Emotiva EMC-3
DAC: Emotiva XDA-2 Gen2
Turntable: Denon DP300F w/ Ortofon 2M Red
Tuner: Rotel RT-1080
Power: Monster HTS 5100 MKII
Amp Power: CyberPower CPS-1220RMS
Interconnects: Emotiva USS [4], XLR [6], X RCA [4], MUSB [1], X IEC [4]
Post edited by Log1x on
Bump.
I was told http://www.soundspeakerrepair.com/speaker-parts-cp/RS-3087/Supplies/Supplies/ would be my best bet elsewhere.
It's $21 ($11 shipping) though. Is that my 100% best bet or is there an alternative that will give that quality (or better) that I can buy locally at a hardware store?
Thanks.
Music [2.2]
Amp: Emotiva XPA-2
Interconnects: Emotiva USS [4], XLR [6], X RCA [4], MUSB [1], X IEC [4] -
Welcome to CP Log1. My eyes aren't what they used to be but that looks like a foam surround, and the adhesive in the link says it's for rubber surrounds. Not sure if that means it will not work others maybe can tell you for sure. If they are foam, you may be better off to replace the whole surround, which many say, and some of the instructions I have seen, does not look too difficult as long as you take your time.
I'd just get a repair kit and re-do both surrounds. They aren't expensive, and it's relatively easy to do. I've done a few sets of speakers now, it's they've all turned out quite well.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Thanks for the replies!
The surrounds are in fact rubber, not foam.
Are there any other suggestions for glue or shall I go with the above?
I'd like to attempt gluing before re-foaming.
My apologize for the late reply.
Thanks,
Brandon
Music [2.2]
Amp: Emotiva XPA-2
