Modded LSi7 vs SDA-2a
dhart86
dhart86 Posts: 1,594
edited July 2010 in Speakers
I have recently come upon a financial dilemma that is causing me to choose between my favorite set of 2-ch speakers. A couple months ago, while I was having the XO's modded in my LSi7's I ran into a good deal on some stock SDA-2a's. I really love both set of speakers for the different sound qualities that they each present. I'm can't decide which speakers to sell.
Consider the following points and tell me what you would do, if you were me
1. My friend will trade me a micrpro 2000 for a 505 sub (and some pool equip)
if I decided to keep Lsi7's
2. Sell the 7's and mod the SDA-2a
3 Are there limitations to modding the 2a's (ie TL mod)
I know listening preferences are subjective, but give me some things to think about
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Post edited by dhart86 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2010
    I'd take the sda's over the LSI 7's.
  • bluecomet
    bluecomet Posts: 1,118
    edited July 2010
    Buy some RDO 194's for the SDA 2a's and you are good to go. If the speakers are for a 2 channel rig, I would go with the SDA's. I like the Lsi7's in a HT setup. The SDA's have a much larger soundstage and will fill up the room with music. I am not sure if you can mod the SDA 2a's. Make sure you indeed have SDA 2a's because some that look like 2a's are 2B's. You would really have to pull the drivers and see which ones you have. That's what I had to do with mine.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • dhart86
    edited July 2010
    OK Thanks ...2 votes for the SDA's. BComet, if SDA's are 2b's what would be different from the 2a's. Does the 2b's have more possibilities for upgrades...Are the sound coming from the mids different btwn the two?
    Does anyone prefer the LSI's for music?
    Main Rig:
    Second Rig:
  • bluecomet
    edited July 2010
    The 2a's have two 5010 drivers. They are also blade/blade. The 2b's can be TL'd and are normally pin/blade. They also have two different drivers.
  • stubby
    stubby Posts: 723
    edited July 2010
    I had a pair of LSi 9's after I sold my SDA's years ago. That did not last long. I bought another pair of SDA's! Even though they are fine speakers with a bit more inner detail, (LSi) I really missed the sound stage and range of the SDA speakers.
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • dhart86
    edited July 2010
    Thanks for the feedback stubby...that really helps, bcomet, mine are blade/blade soI guess they are 2A's
    Main Rig:
    Second Rig:
  • jjwm27
    jjwm27 Posts: 123
    edited July 2010
    i say have a good long listening session and keep the ones that you you keep comparing the other ones to, those will be the ones that set the bar and the ones to keep. i know i might be the only one here but i prefer listening to my modded Lsi9s over my Sda crs all day long, dont get me wrong i love the Sdas i just like the 9s more, but thats just me.
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited July 2010
    IMHO stay with the SDA 2A's. The MW Drivers in the SDA 2A's are all 6510's. I just updated the tweeters in my 2A's to the 194's, replaced 2 of the 6510's, and did some dynamating. The 2A's are a great speaker. The 194's have been in for about 24 hours of play now, and have started to come around. When I first put them in, they sounded a lot like the old 2000's, but I'm hearing a lot less harshness with just that little time for break in. Here is a link that might answer a lot of your questions about the TL upgrade on the 2A's.
    http://www.polkaudio.com/forums/showthread.php?t=97536&highlight=RDO198
    I decided to keep mine as 2A's. I may upgrade the crossovers to newer components, since they are about 25 years old, but that's about the end of it. If you have 2B speakers, then yes by all means go with the TL upgrade. I have a set of 2B's coming that will get the full treatment of mods. Here is a good link to all the tweaks and mods for SDA speakers. http://www.polkaudio.com/forums/showthread.php?t=103506 Hope this helps with your decision.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • danger boy
    danger boy Posts: 15,722
    edited July 2010
    i don't think the SDA2A's can be modded for the TL update..
    PolkFest 2012, who's going>?
  • dhart86
    edited July 2010
    ........thanx everybody for all your feedback. Everybody was recommending the Sda's and I was reasoning that if I'm torn but so many people were thinking SDA...then SDA must be the way to go.........Then jjwm comes and makes a perfect suggestion about a long listening session and go with the one you compare the others to. That approach makes a lot of sense to me. But Dang it, the Lsi7's are like my first loves. Fell in love with those before I ever heard the SDA effect, so I've always compared all speakers to the LSi 7
    jjwm, good suggestion.....I'll try that approach
    Main Rig:
    Second Rig:
  • dhart86
    edited July 2010
    Doug, if I keep the 2A's I will probably get the 194's ....thanx
    Main Rig:
    Second Rig:
  • JPSmario
    JPSmario Posts: 142
    edited July 2010
    danger boy wrote: »
    Yes, they can. see the link:
    http://www.polkaudio.com/forums/show...ghlight=RDO198
    The upgrade is discussed in great detail there.
    Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
    nooshinjohn Posts: 26,086
    edited July 2010
    dhart86 wrote: »
    That logic is not as sound as it seems... SDA's will haunt you, taunt you and tease you like that one girl that got away. Find a way to keep both. It will be like having that faithful wife that doesn't mind sharing you with a mistress.;):D:p:cool:
    PS... I know of no wife that goes for that program, but I don't think the speakers will know the difference.
    edited July 2010
    I agree with John. I have a pair of SDAs I bought used from another member...good price! But I also want to pick up a pair of LSis bookshelves to experience that Vifa tweeter for more than a 'few' listening sessions. It's already one of the better tweeters I have heard and it suits my 'tastes' perfectly. Do they image as well as SDAs with that wall of expanded room filling sound. NO. Do they have the Range and deep BASS of SDAs. No. Are their highs in a class of their own...YES, YES, YES. IMO, neither the original SLs nor the RDOs are quite the Vifa! So for different systems, different rooms. SDAs and LSis! If you can swing it. No need for 'any' decision.
    cnh
  • dhart86
    edited July 2010
    OK after much thought and after an extended listening session (well into the AM) I must report that I agree with everyone's point of view, especially John! John I think your remarks were "on point"(and funny) I'd be regretting selling either speaker, but the SDA's would be haunting me if I didn't have them. Love the soundstage and room filling ability. My modded Lsi' are great as well and probably haven't finished breaking in. I think I need to find another way to raise money! Thanks to everyone for talking me down!
    Main Rig:
    Second Rig:
    edited July 2010
    Glad to be of service.:D:cool:
    heiney9 Posts: 25,612
    edited July 2010
    You can aquire LSi 7's later on if you find you miss them or can use them in another rig much easier than SDA's, both in availability and ease of shipping, etc.
    Keep the SDA's.
  • Bernal
    Bernal Posts: 991
    edited July 2010
    + 1 LSI
    01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    02) SUNFIRE Grand Signature - Bob Carver's and SUNFIRE Cinema Grand
    03) OPPO BDP-83SE Blu-ray Disc Player w/SACD & DVD-Audio
    04) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
    05) DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
    06) HITACHI P55T501. 55" HD1080 Plasma HDTV
    07) POLKAUDIO LSiC (Center speaker)
    08) POLKAUDIO LSi15 LEFT (Front speaker)
    09) POLKAUDIO LSi15 RIGHT (Front speaker)
    10) POLKAUDIO LSiC Vertically (Surround speaker)
    11) POLKAUDIO LSiC Vertically (Surround speaker)
    12) POLKAUDIO LSif/x LEFT (Surround back speakers)
    13) POLKAUDIO LSif/x RIGHT (Surround back speakers)
    14) VELODYNE OPTIMUN SERIES 12"(High Output Digital EQ SubWoofer 2400W/1200WRMS)
    http://www.polkaudio.com/forums/showcase/view.php?userid=98096 (Not updated)
  • jjwm27
    jjwm27 Posts: 123
    edited July 2010
    dhart86 wrote: »
    glad to hear, i dont think you can go wrong with either one. i prefer my 9s but if i ever got rid of the Sdas i know i would regret it.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited July 2010
    Bernal wrote: »
    + 1 LSI
    +1 on the LSis because you own a bunch?
    P.S. Why Don't You Add Your Equipment List To Your Signature Block?:confused:
