Enclosure Help
chilisport
I have a set of SR6500s that I need to break in before I install them in my car. My thought was to build a home center channel with both mids and tweets, and then running the inputs on the crossovers in series for a single 8 ohm load that my receiver can handle.
Assuming this is a decent idea (please tell me if not), how much internal volume should I give them, including ports if necessary.
Thanks in advance for any assistance.
Post edited by chilisport on
Honestly, I'd suggest putting that time and effort into getting a suitable enclosure for your vehicle. Let them break in every chance you get, whether if it's on a trip to the grocery store/gym/etc.
Took my sub about a month to break in, but I do tend to go out at least twice a day minimum.
Btw, welcome to CP!
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Just throw them in your car. Wont take long at all for them to break in. Usually with normal listening, a weeks is all youll need.polkaudio sound quality competitor since 2005
I've read that the SR's can take as long as 60 days to break-in with regular listening. From your responses, it sounds like you both have had different experiences.
Thanks for the input!
