what people think about this setup
XxskevexX
XxskevexX Posts: 3
front rti a7
front central csi a4 or csi a6
subb psw125
rear fix a4
receptor denon avr-591
any feed back will be appreciate for anything
peace out
Post edited by XxskevexX on
  • thuffman03
    thuffman03 Posts: 1,325
    edited June 2010
    What is the size of the room and how loud do you like to play music/movies?
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • packetjones
    packetjones Posts: 1,059
    edited June 2010
    Welcome to the CP.
    The first thing I would recommend is choosing the A6 for the center. Other than that it looks good to me. Enjoy.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • domflane
    domflane Posts: 653
    edited June 2010
    Go for a bigger sub if you can afford it and definately the A6 over the A4.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • XxskevexX
    XxskevexX Posts: 3
    edited June 2010
    my room is 11 by 15 foot is this too loud for my room ? i don't want to buy them for the loud . i prefer the quality 1st . the why i choose this setup rtia7 because i read alot and they are improve from the last version
  • gfong
    gfong Posts: 1,079
    edited June 2010
    My set up is very close to what you are looking into.
    front rti a7
    front central csi a6
    sub SVS PB12-NSD
    rear fxi a4
    My set up sounds great with movies and music. The rti a7's are a little bright for music but kick butt for home theater. Do not get me wrong, the 7's can produce a nice sound with music as lately I have been buying up lots of SACD's and they sound great in multi channel.
    For the rears I choose the fxi4's and really like them for movies and music. I did some research and some people recommended that I change the rears to rtia 3's. I bought a pair and tried them out. I found them too directional for movies/music. I went back to the fxi4's. Down the road I may move up to the fxi6's but for now I am happy with the fxi4's.
    For the center channel go with what others have stated and try and get the A6. Your center channel is so important for movies, you would want the best that you can afford! The A6 fits nicely with the RTIA7's up front.
    Good luck with your choices and have fun with it!
  • XxskevexX
    XxskevexX Posts: 3
    edited July 2010
    thanks gfong for you're reply i really appreciate it and i enjoy that you have the same setup than i want to because it give me a good real feed back from what im looking for .
    now i just want it more an i'll maybe go but it in a bit .
    peace out
