where would you buy repacement legs for a component?`
flat 6
My CD player has short legs that do not allow my amp much breathing room fro cooling. I don't have any way of placing it anywhere but on top the reciever and me tech says thats killing my old carver. where would you look for some longer /taller feet?
Post edited by flat 6 on
There is a guy on Carver forums that manufactures and sells various types of component feet/risers.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I'm not sure who it is but the product is solid....or just go to a Sports Authority and buy hockey pucks.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thanks to bothe of you. I'll check the carver forum (didnt know there was one)
...Hockey Pucks...never thought of that! Might just try it. -
There are two of them... I am pretty sure the guy is on both.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Correction, there is only one Carver Audio forum, http://www.carveraudio.com/phpBB3/
You want to talk with Mr. M-500t or you can visit his site, http://www.avrisers.netPolitical Correctness'.........defined
President of Club Polk -
Those are the hokkypucks I'm lookin for! Thanks, J
Ooo, good idea! -
Yes, I was talking about AV Risers, thank you. And yes, there are two Carver forums (not specifically "Carver Audio"). www.thecarversite.com is the other one, and I am sure you know about it.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
No, there is only one Carver forum. The other site you linked is simply a venue to promote the amp mods done by the pathological liar that runs it.Political Correctness'.........defined
I like to use hockey pucks when needing more room between components.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Brass hockey pucks anyone?
How about some old SIMS german made rollerskating wheels.Bright green.?SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
I've used these cork/rubber pads in the past, about $10/four at your local Grainger store. Adds an additional inch between components.Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!!
this has turned into a pretty cool thread! Keep 'em coming!
Yep, always cool to learn what other people do!
Regarding the cork pads I mentioned, I've noticed other online AV stores sell the exact same product, but at ~2x the price (usually $24/four). And if the lighter-colored cork bothers you, there's always a black Sharpie...Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!! -
I love Granger. They also have chub packs of silicone gaskets for cheap which make great tube dampers. I'll have to check out some of those feet!
