Rear Surround placement??
Hey everyone, I am trying to decide on what to do with my rear speakers. I am running LSI25's and an LSIc in the front and was planning on going with the LSIfx for the back but I have a question. My room is say 20feet long, My couch is not on the back wall opposite from the TV it is at say the 12foot mark.
Should I still go with the Fx's and where should I mount them? Or would I be better off with the Lsi'9s just behind and above the couch? See my professional diagram for reference.
Thanks guys!
Thanks guys!
Post edited by E-ride on
I guess I am mostly wondering about the FX's because of the speaker shape and function? They look to me like they would best be used on the back wall? If I placed them just behind the couch I would have one side firing to the back of the room right?
I am going thru the same dilema as well.You have alot of room behind your couch so you have more options.I did the following:: I got a 6 foot ladder and put my fx's on them to see how much sound I would get from them.I had 9's on stands prior to buying the fx's.My arch way where I will mount the fx's is about 2 foot higher than the ladder test.I felt I got excellent sound from the fx's up so I am going to mount them on the archway behind my couch.Real pic's are helpful so check these out
behind couch pic
Any other thoughts guys? Should I go with the LSiFX's or the LSI9's for my surround speakers? Hoping to pull the trigger this week.
Home Theater 5.1.:
➪ LSif/x
01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
02) SUNFIRE Grand Signature - Bob Carver's and SUNFIRE Cinema Grand
03) OPPO BDP-83SE Blu-ray Disc Player w/SACD & DVD-Audio
04) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
05) DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
06) HITACHI P55T501. 55" HD1080 Plasma HDTV
07) POLKAUDIO LSiC (Center speaker)
08) POLKAUDIO LSi15 LEFT (Front speaker)
09) POLKAUDIO LSi15 RIGHT (Front speaker)
10) POLKAUDIO LSiC Vertically (Surround speaker)
11) POLKAUDIO LSiC Vertically (Surround speaker)
12) POLKAUDIO LSif/x LEFT (Surround back speakers)
13) POLKAUDIO LSif/x RIGHT (Surround back speakers)
14) VELODYNE OPTIMUN SERIES 12"(High Output Digital EQ SubWoofer 2400W/1200WRMS)
http://www.polkaudio.com/forums/showcase/view.php?userid=98096 (Not updated) -
LSif/x:
Dipole/bipole switch allows you to use the speaker to the sides or rear of the listening area.
