where would you buy repacement legs for a component?`
flat 6
flat 6 Posts: 16
edited July 2010 in DIY, Mods & Tweaks
My CD player has short legs that do not allow my amp much breathing room fro cooling. I don't have any way of placing it anywhere but on top the reciever and me tech says thats killing my old carver. where would you look for some longer /taller feet?
Post edited by flat 6 on
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2010
    flat 6 wrote: »
    There is a guy on Carver forums that manufactures and sells various types of component feet/risers.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2010
    I'm not sure who it is but the product is solid....or just go to a Sports Authority and buy hockey pucks.
  • flat 6
    flat 6 Posts: 16
    edited June 2010
    Thanks to bothe of you. I'll check the carver forum (didnt know there was one)
    ...Hockey Pucks...never thought of that! Might just try it.
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2010
    flat 6 wrote: »
    There are two of them... I am pretty sure the guy is on both.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    F1nut Posts: 51,891
    edited June 2010
    Correction, there is only one Carver Audio forum, http://www.carveraudio.com/phpBB3/
    You want to talk with Mr. M-500t or you can visit his site, http://www.avrisers.net
  • flat 6
    flat 6 Posts: 16
    edited June 2010
    Those are the hokkypucks I'm lookin for! Thanks, J
  • zingo
    zingo Posts: 11,258
    edited June 2010
    dorokusai wrote: »
    Ooo, good idea!
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2010
    Yes, I was talking about AV Risers, thank you. And yes, there are two Carver forums (not specifically "Carver Audio"). www.thecarversite.com is the other one, and I am sure you know about it.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    F1nut Posts: 51,891
    edited June 2010
    No, there is only one Carver forum. The other site you linked is simply a venue to promote the amp mods done by the pathological liar that runs it.
  • thuffman03
    thuffman03 Posts: 1,325
    edited July 2010
    I like to use hockey pucks when needing more room between components.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Brass hockey pucks anyone?
    How about some old SIMS german made rollerskating wheels.Bright green.?
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • mak99
    mak99 Posts: 362
    edited July 2010
    I've used these cork/rubber pads in the past, about $10/four at your local Grainger store. Adds an additional inch between components.
    Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!!
  • flat 6
    flat 6 Posts: 16
    edited July 2010
    this has turned into a pretty cool thread! Keep 'em coming!
  • mak99
    mak99 Posts: 362
    edited July 2010
    Yep, always cool to learn what other people do!
    Regarding the cork pads I mentioned, I've noticed other online AV stores sell the exact same product, but at ~2x the price (usually $24/four). And if the lighter-colored cork bothers you, there's always a black Sharpie...
  • zingo
    zingo Posts: 11,258
    edited July 2010
    I love Granger. They also have chub packs of silicone gaskets for cheap which make great tube dampers. I'll have to check out some of those feet!
