In need of a Subwoofer
I just purchased two Polk Audio Monitor 60 and a Polk Audio CS1. I need a recommendation for subwoofer. Newegg has the Polk Audio PSW Series PSW10 for $90. Will that work or should I wait and invest in PSW110 or PSW111? Thank you for your help.
  • geebolt
    geebolt Posts: 215
    edited June 2010
    Newegg still has the PSW505 for $249.00. Thats a great deal and a better sub than better than the others you mentioned.
    Fronts: Polk RTi A7's
    Center: Polk CSi A6
    Surrounds: Polk TSi500's
    Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
    Amplifier: Emotiva XPA-5
    Processor/AVR: Emotiva UMC-1
    DAC: Emotiva XDA-1
    CD player:Emotiva ERC-1
    Blu-Ray: Oppo BDP-93
    Turntable: Kenwood KD-500
    Tonearm: Polk-Mayware Formula 4
    Cartridge: Shure M97-XE
    Television: Sony KDL-55EX500
  • mudwrx
    mudwrx Posts: 367
    edited July 2010
    I recently got the PSW505 (yup, $249 from newegg). This thing will shake the walls, great deal. Just beware of the size, it is a 12" sub and will take up some space.
  • thuffman03
    thuffman03 Posts: 1,325
    edited July 2010
    I would not go with the PSW10. You will spend the $90 and wish you could get your money back.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • lindseyclaytor
    lindseyclaytor Posts: 1
    edited July 2010
    It depends on your needs. I have a PSW10, in a stereo system. Harmon Kardon amp, JBL Studio monitors. Sounds great, reproduces music very well (I'm a Bass player). Of course I am not looking to shake the walls, vibrate the windows. Just want good clean sound. Can't go wrong for this quality and price.
