New 2 Ch Arrangement
VR3
VR3 Posts: 29,610
edited July 2010 in 2 Channel Audio
I was having some odd bass problems in the old configuration
With the new configuration and some minor late night tweaking I definitely have more, lower bass -- just matter if it is more accurate
I think it looks a little cooler either way...
Any ideas on other sub placements?
Post edited by VR3 on
  • Face
    Face Posts: 14,340
    edited June 2010
    Looks MUCH better than that old bedroom setup.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited June 2010
    God, you have completely gone off the deep end. No more Sid the Kid.
    Placement, study up on quarter and half waves in relation. I don't care for the speakers, but they should be putting out plenty of low end, even without the sub agumentation.
    Then again, you've had SVS and VMPS, why did you change? Dalhquist used the same SEAS driver (much earlier version), and only used it to take the DQ10's down from 40Hz to 32 Hz. Not that it will / won't help, but I'd put the amps where the speakers are, and move them (the speakers) out in the room with the subs behind them (again, following the rules to not cancel the quarter and half waves).
    Looking at the pics only, your bass traps are WAY too small. Those need to be in the rear corners, you need something MUCH larger up front.
    You been smokin' too many treats? Anywho, I'm proud of you.
    Cheers,
    Russ
    VR3 Posts: 29,610
    edited June 2010
    Thanks for the comments thus far - Ill look into quarter and half waves ---
    Haha, I know alot of folks dont like Tyler Acoustics - I dig it.
    I have the mains set up really strange and I really like it - I sit maybe 6 ft from the CD player -- where as the normal sweet spot would be approx 10 ft or so from the CD player. Kind of like a near field in a far away setup - and the speakers have a 3/8" tilt back - so I get a mean, large center stage. Which I really like - not mention a lot of width.
    The super towers do not have alot of bass, the 7u had far more bass with less of the same drivers. Dont get it - the drivers hardly move where as the 7u drivers were jumping out of the enclosures.
    Either way, they sound down right anemic without subs.
    The subs go down to about 25hz or so - but the tonality and accuracy of them is far above the SVS and VMPS I had previously - I do plan to acquire one of my old VMPS for HT again - that is in the works.. probably another XTi1000 bridged to drive it...
    hhaha but thank you though -- It has been a long journey up until this point - hell I remember when me and you were designing the transmission line speakers... haha loads of fun. Those speakers sounded pretty darn good too.
  • Face
    Face Posts: 14,340
    edited June 2010
    VR3 Posts: 29,610
    edited June 2010
    haha my room is pretty much the exact dimensions of the first golden room. This room has incredible acoustics - when I bought the house the second I walked into the den I knew I wanted it - I just wish I had paid closer attention to the rest of the house now obviously hahahahha
    But either way - cool link!
  • Ricardo
    Ricardo Posts: 10,634
    edited June 2010
    I think a color change would do wonders for the room acoustics ;)
    SOPA
    VR3 Posts: 29,610
    edited June 2010
    Pictures do not do the color justice - the flash makes it look like it glows in the dark or something. It is actually a very dark orange that I think is pretty cool!
  • unc2701
    unc2701 Posts: 3,587
    edited June 2010
    What frequency do you have them crossed in at?
    Backburner:Krell KAV-300i
    VR3 Posts: 29,610
    edited June 2010
    I have found in this room, with the super towers, that 80hz and about 1/4 volume in normal phase with a 2.5db bump at 32hz seems to work great...
    Now with the 7u I would cross my subs around 40-60hz and run them around the same volume. Still cant figure out why the Super Towers are anemic in the bass - must be the crossover design hmmm
  • Conradicles
    Conradicles Posts: 6,393
    edited June 2010
    I saw the room in person and it does look much better than one would think.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2010
    change the toe-in of the vacuum a bit. lose the paint chair and its not a Sid Rig till you get the toy off the shelf and on the rack.
    have you run any sweeps to actually know what is going on with the bass???
    RT1
  • madmax
    madmax Posts: 12,434
    edited June 2010
    Excellent use of symetry. I like the room colors too! NICE!
    madmax
    Vinyl, the final frontier...
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited June 2010
    RT1
    My thoughts exactly.:D
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • schwarcw
    schwarcw Posts: 7,360
    edited June 2010
    I'm with Face, put the subs in the center of the side walls and in the center of the rear wall. George Cardas knows his stuff!
    Carl
    treitz3 Posts: 20,188
    edited June 2010
    Thing is, the center of the rear wall is his front door.
    VR3 Posts: 29,610
    edited June 2010
    I rearranged it again ---
    I did the 1 ft from the rear wall and 1.6 from the side (but where it is 4 ft from the rear - etc)
    It ended up being 6 ft apart and the sweet spot to my ears is 3 ft away from the CD player... but huge difference in tightness... I am going to slowly back it up - just wanted to tinker tonight is all
    VR3 Posts: 29,610
    edited June 2010
    Rearranged it again and man does it sound amazing following the 1 x 1.6 formula with some slight toe in.
  • dougy
    dougy Posts: 182
    edited July 2010
    very interesting. especially the wall-mounted components. different! and I like the symmetry also. never heard (or seen) Tyler Acoustics (other than pics), but they look good, with obviously good Q drivers. not feelin the paint scheme -ha
    THE MAN-CAVE 5.1 CHANNEL A/V RIG
    Sony KDS-60A3000
    a/d/s/ HT-400LCR (3)
    a/d/s/ HT-300 (2)
    Velodyne DLS-4000R (2)
    Pioneer Elite VSX-55TXi
    Pioneer Elite DV-47Ai
    Sony BDP-S300
    Sony SLV-779HF
    DirecTV HD sat. receiver
    MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
    Adcom GFA-5500
    Bose 901 Series VI
    NAD C-165BEE
    Slim Devices Squeezebox Classic
    TEAC CD-RW890
    Technics SL-BD20D w/ Audio-Technica P34
    Akai HX-A3X
    VR3 Posts: 29,610
    edited July 2010
    haha - I dont blame you for not liking the paint through the pics - it sucks! haha
    In person though its neat, I didnt like it at first but it has really grown on me. Makes the den a very inviting place and chill (so to speak)
    Thanks for all the comments
  • organ
    organ Posts: 4,969
    edited July 2010
    Holy crap! Is this the same bedroom? Very nice set up! I bet the dog enjoy the speaks too:).
    VR3 Posts: 29,610
    edited July 2010
    Haha thats Organ!
    Not the same bedroom by any means - but same system in my house! :)
    Here are the current pics and it sounds 10000000 times better this way. I wish I had done this months ago.
    This is setup with the Cardas method and with the subs put in the seating position and me walking around.
    Note the subs are currently not hooked up
    VR3 Posts: 29,610
    edited July 2010
    Hmm I guess it would help if I upload the pics
  • Face
    Face Posts: 14,340
    edited July 2010
    The towers look like they're against the back wall.
    VR3 Posts: 29,610
    edited July 2010
    Hehe - amazing what a camera will do.
    They are approx 2 ft from the back wall and 3.2 ft from the side wall (from the center front of the woofer)
    Definition, detail - bass response, everything is far superior to where they were before...
  • quadzilla
    quadzilla Posts: 1,543
    edited July 2010
    RT1
    Nah, it's obviously the dog causing an early reflection problem and probably causing a null as well. Just look at the eyes. You should have one behind each speaker curled up with the tail over the nose.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
    VR3 Posts: 29,610
    edited July 2010
    The dog usually stays to the left stage - I find it helps the reflections on the floor quite a bit!!
    Her real reason for being there is absorbing AC.... all of it
