LSiFX with With RTi fronts?
Would there be any issues using the LSiFX surrounds with RTi fronts due to the difference in the impedance between the speakers? I'm using a Harman Kardon Signature 2.1 amp to power my speaker which drives 100 WPC into 8 ohms, and 150 WPC into 4 ohms (very conservatively rated as HK tends to do).
My System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
Media Room
Living-room
Headphones
Post edited by mystik610 on
IMO, No, there shouldnt be an issue as the surrounds provide ambient sounds, and not AS important in a 5.1 set-up.
DavidPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
No.
100W/8 is more than enough for rears, hardly any sound actually comes out of the rears.[ Home Theater ] 3 x LC265i for LCR and LC80fx rears plus Velodyne DD15 subwoofer using Denon 3808a processor with custom 5 channel amplifier and Oppo BDP-83 player. -
I guess my real question is....are there any issues involved with hooking a pair of 4ohm speakers up to the same amp and/or receiver as a set of 8 ohm speakers?My System Showcase!
Media Room
Living-room
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun -
Shouldn't be an issue at all. -
Just do an auto calibration and it will be safe
Right now I use polk rti8 as surrounds and it sounds quite good considering my fronts are all electrostats .I have to respectfuly disagree with surrounds not being as important as the fronts though
Surround sound speakers used to be just for ambience but now they are becoming equaly important as studios are incorporating alot more into the mix . When I watched the GREENZONE last week I could realy tell that I need electrostats for surrounds and it shame'd my rti8 -
no your amp should be able to run it just fine.
