LSiFX with With RTi fronts?
mystik610
mystik610 Posts: 699
edited June 2010 in Speakers
Would there be any issues using the LSiFX surrounds with RTi fronts due to the difference in the impedance between the speakers? I'm using a Harman Kardon Signature 2.1 amp to power my speaker which drives 100 WPC into 8 ohms, and 150 WPC into 4 ohms (very conservatively rated as HK tends to do).
My System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
Post edited by mystik610 on
  • Knucklehead
    Knucklehead Posts: 3,602
    edited June 2010
    IMO, No, there shouldnt be an issue as the surrounds provide ambient sounds, and not AS important in a 5.1 set-up.
    David
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • SoundEngine355
    SoundEngine355 Posts: 12
    edited June 2010
    mystik610 wrote: »
    No.
    100W/8 is more than enough for rears, hardly any sound actually comes out of the rears.
    [ Home Theater ] 3 x LC265i for LCR and LC80fx rears plus Velodyne DD15 subwoofer using Denon 3808a processor with custom 5 channel amplifier and Oppo BDP-83 player.
  • mystik610
    edited June 2010
    I guess my real question is....are there any issues involved with hooking a pair of 4ohm speakers up to the same amp and/or receiver as a set of 8 ohm speakers?
    My System Showcase!
    Media Room
    Living-room
    Headphones
  • pearsall001
    pearsall001 Posts: 5,256
    edited June 2010
    mystik610 wrote: »
    Shouldn't be an issue at all.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2010
    mystik610 wrote: »
    Just do an auto calibration and it will be safe
    Right now I use polk rti8 as surrounds and it sounds quite good considering my fronts are all electrostats .I have to respectfuly disagree with surrounds not being as important as the fronts though
    Surround sound speakers used to be just for ambience but now they are becoming equaly important as studios are incorporating alot more into the mix . When I watched the GREENZONE last week I could realy tell that I need electrostats for surrounds and it shame'd my rti8
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2010
    mystik610 wrote: »
    no your amp should be able to run it just fine.
