Rti-A9 help
rrclassicjoe
rrclassicjoe Posts: 1
edited June 2010 in Speakers
The top two 5-1/4"s and the tweeters on my Rti-A9's just qiut working. I'm really not sure where to start troubleshooting. The bottom six subs work fine. Is there an obvious fix to this or am I going to need to do some serious detective work?
Post edited by rrclassicjoe on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2010
    Check the jumpers in the rear and make sure they're connected.
  • BeefJerky
    BeefJerky Posts: 1,320
    edited June 2010
    First, make sure that the jumpers are still in place on the back of the speakers and that all four the binding posts are secure. If that doesn't fix it, I recommend replacing the jumpers with short pieces of wire. Sometimes the jumpers just don't make a good connection, and that cause the problem you are having.
  • Gulfstrings
    Gulfstrings Posts: 313
    edited June 2010
    Did this happen on one or both speakers?
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Technics SL-1301/Shure M97xE
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
    Antec VERIS A/V Cooler x 2
