Sonic Barrier BlackHole in my SDA 1C's
24
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2010
    Larry, did you cover the entire interior surface with the blackhole and sonic barrier, or did you leave some of the interior walls exposed? Did you cover the top and bottom with it as well?
    I'm getting ready to start doing some mods to my 2A's, and this is one of the mods that's on my list.
    I'm probably just going to go with the cheaper Sonic Barrier stuff for now, and possibly switch the back walls to the Blackhole stuff eventually. I'm just trying to figure out how much of it I'd need.
    The interior dimensions of the cabinets are roughly 37" high, 15" wide and 10" deep. The Sonic Barrier comes in 18x24 sheets...so I guess two sheets per cabinet would be about right for the back walls, with a little bit extra left over.
    How much do you think I'd need for the sidewalls? Another three sheets per cabinet maybe? How much of the Sonic Barrier did you have to use for the sidewalls of your 1C's?
    Should I just reuse all of the stock poly fill, and put it back in the same, original location? Should I add more polyfill? If so, where and how much?
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • george daniel
    george daniel Posts: 12,096
    edited June 2010
    How about an update now that you've had them for awhile.I know that there was some talk about the larger SDA's,, but,I'm interested in your impression now that you've had some time with them.I'm planning on popping the stuff in when I pull the drivers for the ring upgrade,which I might add,it probabally the biggest tweak-quality of life improvement for SDA owners in the past decade.
  • Janne
    Janne Posts: 139
    edited June 2010
    I was also considering this but cancelled after his reply.
    This is what I got from him by mail.
    "DONT DO IT!!!!!!
    I hated it after some real listening, and took it all back out.."
    HT/2 CH
    McIntosh MX120, MC500, MC206, MEN220
    polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
    MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect.
    Toolfan66 Posts: 18,081
    edited June 2010
    Yep!!!! Save your money....
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2010
    So it's good on the smaller SDA's but kills the life of the music in the larger ones. Is that it Larry?
  • george daniel
    edited June 2010
    hmmm lemme' re phrase--still got the blackhole in the 1C's?
    edited June 2010
    Yep!!!! The highs are fantastic you can't beat it, It's to die for. But the Lows is what kills it for me, it gets deep but too deep to the point of a rumble...
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2010
    OK Larry, make it clear for us....
    You like it in the 1C's, but not the 1.2's?? Is this correct?? Too much bass in the big boys??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hearingimpared
    edited June 2010
    vmaxer wrote: »
    IMHO there can never be too much bass but when it goes to becoming rumble that's a different story and that, I believe, is what Larry is talking about.
  • nduitch
    nduitch Posts: 316
    edited June 2010
    Have you tried experimenting with a smaller amount? When you have the time of course.
  • george daniel
    edited June 2010
    vmaxer wrote: »
    thats my impression.
  • george daniel
    edited July 2010
    just as an update;; I have been hesistant about the blackhole project,,so while I was installing my rings,,I cut several pieces and popped em' in one speaker,buttoned it back up,,and I gotta tell you,,the sound seems "fuller",,imagine the SDA effect with more "meat",,and a much improved "focus" with vocals and instruments as well.Initial impressions are positive,,overall I was say that the sound is less"hollow",,with an improved "body". Today I'll compare speakers with rings vs rings/blackhole(blackhole on the top-bottom-back--the other stuff on the sides.
  • hearingimpared
    edited July 2010
    Thanks for the info George.
  • george daniel
    edited July 2010
    Well, after 2 songs,the SDA effect is improved,,vocals and imaging are spot on,my wife (who has better ears than me) summed it up"it kinda' sucks you in",,.I had listened to my reference recording(for me) Joan Baez,"Diamonds and Rust" and I just became lost in the music,,it's difficult for me to put into words,,it's like the speakers are "larger" than they really are,if that makes sense.There seems to be more of a "presence".I'll do some more listening and follow up,,one thing for sure,it ain't subtle.
  • nduitch
    nduitch Posts: 316
    edited July 2010
    What parts of the Cabinet are you putting the Blackhole?
    nooshinjohn Posts: 25,932
    edited July 2010
    Has anyone tried these mods on the 2.3TL's...
  • Des Moines
    Des Moines Posts: 115
    edited July 2010
    George, did you decide to just put in a few pieces of the 3/4" black hole on the sides only?
    The issue I have with using black hole or sonic barrier on the back cabinet wall is that it is mostly covered by the stock polyfill anyway. For this reason, I thought about doing only the cabinent sides with sonic barrier.
    HT in Progress
    Receiver - Harmon Kardon AVR520 5.1
    Fronts - Polk SDA 1C
    Center - Polk CS350
    Monitor - Sharp Aquos LCD
    NMT - Mede8er500x
    Cables - Signal Ultra
  • george daniel
    edited July 2010
    Guys,, I put the Blackhole on the back,bottom and top,, then I used the stuff I got from Partsxpress on the sides,, the result ain't subtle,,I also installed the "rings" that I got from Larry,,as far as the polyfill,,I placed it back in the cabinet.IIRC Larry tried it in his 2.3's and did not like it.I know that he had it in his 1C's as well,,but don't know if he left it in or removed it.I can say this,,vocals are much clearer,the SDA effect is more prominent(to my ears) and like I said before,,the music just kinda' grabs you and pulls you in,,lower volume resolution and detail are fantastic,,bass is very tight--lemme' do some crtitcal listening,before I pass judgement.If you don't have the "rings",,get em'' thet are that good.Thank you Larry. :)
  • Face
    Face Posts: 14,340
    edited July 2010
    Des Moines wrote: »
    Behind the drivers would be more effective.
    edited July 2010
    I left it in my 1C's I love the detail, George is right it does grab you and pull you in. In my 1.2tl's with the lower end i would get vibration and a rumble. Now I kinda wish I would have left the back wall in place and tried that.
  • george daniel
    edited July 2010
    I've been looking for a word to describe the sound,,all I can come up with is Meat
  • hearingimpared
    edited July 2010
    Oh no! . . . and I thought I was free and clear with the blackholes in my 1.2TLs!:eek::p
  • Des Moines
    edited July 2010
    Thanks for the report. I will follow your lead and Face's reco and install on the back, top, and bottom. Already installed the rings and they are the perfect combo with mortite.
    HT in Progress
    Center - Polk CS350
    NMT - Mede8er500x
  • george daniel
    edited July 2010
    Just for the record,, I also used the sonic barrier stuff on the sides. After some listening this evening,, the soundstage with the 1C's is deep and wide and very easy on the ears,,detailed,,yet far from being bright,,if SDA's are your thing,, then,,prepare yourself,(yes Virginia,,it grew),BTW,I'm running mine with a little 40 watt tuber.
    Ethereal--thats it.
  • Conradicles
    Conradicles Posts: 6,344
    edited July 2010
    George, does it hurt the bass at all?
  • george daniel
    edited July 2010
    a tad tighter-- certaily not overpowering.
  • Conradicles
    edited July 2010
    Thanks George. I'll tell you what those rings made a nice improvement to my SDA-1's and my next purchase will be more room treatments. I'll follow this thread as well...keep us posted...
  • frodaddy
    frodaddy Posts: 124
    edited July 2010
    What is the "SDA effect"?
    Fronts: DIY Statements from htguide.com
    Center: DIY custom Statement center from htguide.com
    Surrounds: Four DIY custom Mini Statements
    Wire: HD-14
    Receiver: Denon AVR-4806 + CI upgrade
    Amps: Dual Emotiva LPA-1's
    Sub: Infinite Baffle: 8 fiCarAudio IB315 woofers, Behringer DSP1124P EQ, Elemental Designs eQ.2, Dual EP4000 amps
    Transducers: 2 buttkicker LFE's, BK amp, EQ'd w/DSP1124p
    DVD: Toshiba HD-XA2 / PS3
    TV: Samsung 1080p 61" DLP
  • hearingimpared
    edited July 2010
  • muncybob
    muncybob Posts: 3,245
    edited July 2010
    sheez!! Everytime I start reading new threads in here there us yet another mod I need to put on "the list" for my totally unmodified 2b's.......stop it already!! :)
    but seriously, I want to take apart my speakers only 1 time and I'm thinking that this will be a mod to do on the 2B?(along with the 5 other on my list!). I ask this since it's mentioned that this mod works well on the smaller SDA of which I think the 2B falls into that category?
    Yep, my name really is Bob.
