Need help choosing surrounds
Hey all,
I recently picked up a pair of M70's for fronts and a CS2 center channel, should i get Monitor30's or 40's for the surround in a 5.1 setup? My room is fairly small (apartment living room 14 x 12).
Thanks!
Thanks!
Post edited by Kupo on
Monitor 40's should do good and match with 70s.Denon 2310CI
Fronts: Polk Audio M70
Front Height: Polk Audio M30 (PL IIz Height)
Center: Polk Audio CS2
Surround: Polk Audio M60
Panamax M4300 power conditioner
Pioneer KRP-500M Kuro Plasma 50 Inch(Love it!)
Oppo 83 blu ray player
Roku Xr (Enjoying Pandora, Netflix and many..)
DTV-5000HD(Electronic Master,renamed from Digiwave) HD TV tuner -
Welcome both of you to Club Polk!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I'm kind of partial to the Monitor 30's myself.
Don't know your physical room setup, but the 30's will wall mount very nicely and are a heck of a speaker for their price/size.
If you have the room/moolah, the 40's will certainly fit right into your 70's/CS2 setup seamlessly.
Also, as Cfrizz mentioned, "Welcome !".
Sal Palooza -
welcome!
My personal problem with the 40's is that they seem rather large. If you can fit them in your room without problems (mounted, on a bookshelf, on a stand) then go for the 40's. If you want to sacrifice a little on the sound to have a more reasonably sized surround speaker then go with the 30's. From what I have read both sound great. The 40's may just have a wider range of sound?
If you want a floor standing speaker you could always buy a M50 or M60 as well. They will sound somewhere between the 40's and 70's and match up with your 70's well. Also don't need to worry about stands or mounts.HT and Music Rig
Receiver- NAD T765 HD
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Surrounds side- Polk Audio Monitor 60
Sub- Polk Audio PSW505
Windows 7 Media Center
T.V.- 40" Sony Bravia LCD 1080P
Blu-Ray- 80 GB PS3 -
I have a similar set up with m40 rears. I vote for m40`s.. Both would work well.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand -
not to hijack the thread... but im interested too... im in the market for rear surrounds and i have a similar setup, cs2, monitor 70's..... only im running a 7.1 so i have the monitor 40's for my side surrounds im wondering if i should do monitor 30's for the rears or another set of 40's? the good people at monoprice make an awesome mount for the 40's so thats not a problem......
mid day bump.....
