Need help choosing surrounds
Kupo
Kupo Posts: 1
edited June 2010 in Speakers
Hey all,
I recently picked up a pair of M70's for fronts and a CS2 center channel, should i get Monitor30's or 40's for the surround in a 5.1 setup? My room is fairly small (apartment living room 14 x 12).
Thanks!
Post edited by Kupo on
  • sam1233
    sam1233 Posts: 31
    edited June 2010
    Monitor 40's should do good and match with 70s.
    Denon 2310CI
    Fronts: Polk Audio M70
    Front Height: Polk Audio M30 (PL IIz Height)
    Center: Polk Audio CS2
    Surround: Polk Audio M60
    Panamax M4300 power conditioner
    Pioneer KRP-500M Kuro Plasma 50 Inch(Love it!)
    Oppo 83 blu ray player
    Roku Xr (Enjoying Pandora, Netflix and many..)
    DTV-5000HD(Electronic Master,renamed from Digiwave) HD TV tuner
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2010
    Welcome both of you to Club Polk!
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited June 2010
    I'm kind of partial to the Monitor 30's myself.
    Don't know your physical room setup, but the 30's will wall mount very nicely and are a heck of a speaker for their price/size.
    If you have the room/moolah, the 40's will certainly fit right into your 70's/CS2 setup seamlessly.
    Also, as Cfrizz mentioned, "Welcome !". :)
  • buccidiego
    buccidiego Posts: 75
    edited June 2010
  • nedh84
    nedh84 Posts: 143
    edited June 2010
    My personal problem with the 40's is that they seem rather large. If you can fit them in your room without problems (mounted, on a bookshelf, on a stand) then go for the 40's. If you want to sacrifice a little on the sound to have a more reasonably sized surround speaker then go with the 30's. From what I have read both sound great. The 40's may just have a wider range of sound?
    If you want a floor standing speaker you could always buy a M50 or M60 as well. They will sound somewhere between the 40's and 70's and match up with your 70's well. Also don't need to worry about stands or mounts.
    HT and Music Rig
    Receiver- NAD T765 HD
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds side- Polk Audio Monitor 60
    Sub- Polk Audio PSW505
    Windows 7 Media Center
    T.V.- 40" Sony Bravia LCD 1080P
    Blu-Ray- 80 GB PS3
  • over50
    over50 Posts: 201
    edited June 2010
    I have a similar set up with m40 rears. I vote for m40`s.. Both would work well.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    B&K ST.3140 Power Amplifier
    HSU Research VTF2 MK3
    Vizio P65-C1
    Panasonic 605 blu ray
    Onkyo DS-A4 i-pod Dock
    Universal Remote
    BDI Icon 9429 TV Stand
  • reapergato
    reapergato Posts: 8
    edited June 2010
    not to hijack the thread... but im interested too... im in the market for rear surrounds and i have a similar setup, cs2, monitor 70's..... only im running a 7.1 so i have the monitor 40's for my side surrounds im wondering if i should do monitor 30's for the rears or another set of 40's? the good people at monoprice make an awesome mount for the 40's so thats not a problem......
  • reapergato
    reapergato Posts: 8
    edited June 2010
    =) mid day bump.....
