MIT impedance settings
heiney9
I have a pair of std RCA MIT Shotgun S2 interconnects I plan on running between my amp and pre-amp. These have a 3 position impedance switch how do I determine where to set the switch
The Aleph 30 has an input impedance of 47 Kohms
The Adcom 750 has an output impedance of 600 ohms
Any help or explanation would be great.
Post edited by heiney9 on
Where they sound the best.
madmax
Not the answer I was looking for. Trying to understand the mechanics of why they need impedance matching.
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Rtfm.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I was under the impression it did, but it's been a long time since I read it(or any manual).
EDIT: Are you using the 750 in passive mode at all times? Does it have an input buffer?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
H9, Doubt I am answering your question but the impedance setting on the MITs should be set to what is a close match to the Preamps input impedence.
I have S3s. I forget what setting I used on my 750.Speakers: SDA-1C (most all the goodies)
I just recevied the Shotgun S1.3 ICs last week, and the instructons say to set the impedence to the input impedence of the cable destination. The output impedence is not used for the cables. Mine were XLR so they could only be installed in one direction, but I believe RCAs are directional.
The confusion issue for me is the upper low end range on the settings extends into the low end of the mid range setting. Anyway, mine are set at the low end, and they sound great. Maybe I might try the mid setting at some point in the future once I am 'used' to the new sound of these cables.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Ha, no mostly active and some passive, but here's the kicker. Most of the time I run the Dared tube pre-amp through the HT bypass on the 750, especially for serious listening sessions. I wouldn't think that would change the impedance."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
use the input impedance of the component receiving the signal but r u wanking this or what
reeltrouble1 wrote: »but r u wanking this or what
If you are referring to the tube pre running through the HT bypass, no it does exactly what it's supposed to do, pass the signal straight through. I do this because sometimes I don;t have time to listen to tubes so this way I can turn on the Adcom 750 and listen to music without having to worry about warming up the tubes or short on/off cycles of the tube gear. It's especially nice when I want to watch a movie I can just run the SS gear saving tube life.
r u trying to match my dribble.......................good luck, U dont know where to set the switch.........waaaaaaaaaa, must be a slow day, sure is for me, feels good. Anyway, when I had the Dodd Tom now has I did that with its by-pass, had some nice Tele smooth plates in it, but alas, in the end the two-channel was missing that last 3.83%% or so on the Rabbit Hole scale of Ear Candy Magic so I built the HT room and 2-ch Room, oh yea, I bought a few components, hi-fi stuff as they say. So U have been getting your hi-fi on for a bit, no doubt, good luck though with the switch thingy.
RT1 -
reeltrouble1 wrote: »use the input impedance of the component receiving the signal but r u wanking this or what
So if the input impedance of the amp is 47 Kohms, then set accordingly? Yep, slow day here, beautiful day as well.
its what I would do.
so you see Tubes add Soul
and Tubes add Warmth
and Tubes do it with a Matched Mate
the correlation to the essence of life is evident
Tubes Rule.
MIT Rocks.
RT1 -
I do that all the time
LOL....you're not alone Heiney. I usually keep mine in the middle for all gear since I've found it's the most common set of values.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
You got it.
President of Club Polk -
Brock if the input impedance of the target component falls between two different settings on the box, I've found that the higher switch selection sounds best. I asked Joe Abrams about this when I was wiring up all my components and this is what he recommended . . . to my ears, he was right.
OK, I guess you could set them to where they sound the worst.
Impedance matching allows maximum power transfer and probably some slight change in the frequency curve. If it were RF it would deal with reflection but at audio frequencies I don't think this is relevant. In actual use of these little switches I notice a wider more open soundstage at one extreme or more detail and cohesivness at the other extreme. No matter the case its still a tradeoff and what matters is what sounds best to you given your system characteristics.Vinyl, the final frontier...
