Replacing Peerless tweeters in Monitor 10A
dadofzman
dadofzman Posts: 2
edited June 2010 in Vintage Speakers
One tweeter is not operating in my 10As. The fuse is fine, wiring is fine; the other tweeter works when transferred to the bad speaker. I understand that the Peerless HF1000 tweeter is no longer manufactured. Can anyone suggest obtaining a matching replacement, or which 'other' tweeter would be an effective/close-to-matching replacement, or general issues in tweeter replacement? thanks.
Post edited by dadofzman on
  • bluecomet
    bluecomet Posts: 1,118
    edited June 2010
    I have a pair of peerless tweeters I am thinking of selling. Let me know if you are interested.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • dadofzman
    dadofzman Posts: 2
    edited June 2010
    Hello bluecomet. I am interested in the tweeters. I do not have enough posts to reply privately. can you reply to dadofzman@yahoo.com thanks.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited June 2010
    Even though the fuse looks OK, sometimes there is poor contact between the fuse and the fuse holder due to corrosion. If you don't have contact cleaner readily available, remove the fuse and use a piece of speaker wire as a jumper to test it.
    Oops, NM, I see where the other tweeter works in the other cabinet.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • bluecomet
    edited June 2010
    I will email you tonight.
  • geppy1
    geppy1 Posts: 3,076
    edited June 2010
    Make sure you are getting the right ones. Are they marked 7514___ (Made in Denmark) or 5514 (made in USA). Being 10As they should be 5514__ HOWEVER there are about 4 versions of that one AND THEY DO NOT SOUND THE SAME. Do you have a picture of the back of your tweeter???
  • bluecomet
    edited June 2010
    PM sent. I have the correct tweets for you.
  • I’m looking for one tweeter for my Monitor 10a. I see that this thread is very old, but just thought I’d ask.
    F1nut Posts: 51,943
    Try eBay.
