mm2124
Systems
Systems Posts: 14,872
edited December 2003 in Car Subwoofer Talk
ok i went to circuit city today and listin to subs couse im goin to upgrade my system this summer.anyway i listin to the new 12 inch momo and the 10 and the 10 sounded preatty good and the 12 sounded like it was vibratin the hell out of somthin so i couldent really tell how good it sounded and i had it runnin on the new momo amp.i also listin to the mm12 in the custom box and gnx 124 and the gnx124 sounded the best out of them all.but my question is isn't the momo spost to be a real awsome sub and the gnx124 blew em away????i had the volume on the alpine indash turned up between 10 and 15 the alpine indashes are preatty loud between that volume
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    the mm124 requires an assload of power -- 500 watts +++
    it sounds great under that power... when u put it on a piddily **** 150 watts, forget about it.
    the gnx is a 150 watt sub -- and on 150 watts it probably sounded better than the momo 124 on 150 watts. get my drift?
    my personal pick out of all those subs would be two of the new mm2104 or 2124 -- put about 300 - 350 watts on each and call it a day -- something like an mtx 801D would be a good amp for them.
    The Artist formerly known as PoweredByDodge
  • Systems
    ah cool thx im gettin my drivers licence next week and im goin to cc to listin to them agan the 2124 sound like it was vibratin the hell out of the stand it was on so im goin to a diffrent cc to listin to it.
    Testing
    Testing
    Testing
  • Systems
    hey do you know any website that sells monster cable amp wiring kits? besides the monster cable web site?
    Testing
    Testing
    Testing
  • PoweredByDodge
    i dunno about monster cable, but good cheap kits can be had at www.sounddomain.com and www.mitekfactoryoutlet.com
  • MTXMAN
    MTXMAN Posts: 682
    BIG downside of listening to MOMO subs at CC... Corporate in it's undying wisdom (not sarcasim) has declared that the momo's shall be displayed in ported enclosures. these subs do best in sealed enclosures so when you set them up in your car you'll get better SQ from them by going with the reccomended sealed enclosure...
    Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax.
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    really mtx?
    what about the big momos? (124 and 104), they dont last long in ported boxes
    -Cody
  • MTXMAN
    MTXMAN Posts: 682
    with the ecception of the MM12 all MOMO subs are in ported enclosures, i went into my old CC to listen to the MOMO coax's and rub in the fact that i had the day after thanks giving off and went off on one of the newer sales reps about it... I was realy giving the guy a hard time mainly cause the box was one of the Q-Logic boxes that can either be ported or sealed thanks to a removable plastic cap and i was trying to get him to put the plug in, that and the little **** put a Audiobahn amp on it... DAMN CC... I hate corporate decisions from idiots who think the bose system in their car is good.......
