Connecting RCA from amp to LFE on Sub ?
punit
Hi,
I have a pair of LSI9's hooked up to a NAD C 375BEE Integrated Amplifier.
http://nadelectronics.com/products/hifi-amplifiers/C-375BEE-Integrated-Amplifier
I want to add a subwoofer & was think of buying the Definitive Tech ProSub 1000 as am getting a good deal for it.
http://www.definitivetech.com/Products/products.aspx?path=Subwoofers&productid=ProSub%201000
The sub has only LFE input with a variable low pass crossover from 40 Hz – 150 Hz. Can I connect the Tape Monitor RCA out from my amp (using a Y cable) to the LFE input of the Sub ?
MAC Mini 3.1, OSX 10.6, 2.53 GHZ, Intel Core 2 Duo with SSD & 6 GB Ram, Audio GD NFB-7,2009 Macbook Pro 15" 4 gb ram OS 2.5 Ghz X 10.5.8, Apogee Duet, Signal Cable Silver Resolution Cables & power chords through out the system,Isotek GII Vision, Polk Audio LSI9 speakers (2 pairs, one with Custom external crossover by Sking Ninja), Cayin / Spark AT70 integrated amp, Audio GD Master 1 pre amp, Rotel RB1080 power amp.
Post edited by punit on
Hi,
The sub has only LFE input with a variable low pass crossover from 40 Hz 150 Hz. Can I connect the Tape Monitor RCA out from my amp (using a Y cable) to the LFE input of the Sub ?
I don't see that as a problem. You will just adjust the cutoff on the sub. Your L/R speakers will be full range.
