Is this the right Capacitor?
drselect
I am working on the 4.1TL mod to my SDA CRS+ and was wondering if I ordered the right capacitors from Sonic Craft? In reviewing the other posts on the 4.1TL mod I have not seen the capacitors used have the "Gen I" labeled on the capacitor. I did specify the Gen I capacitor but now after rereading F1nut thread (http://www.polkaudio.com/forums/showthread.php?t=40577) on his 4.1 TL mod I am not sure if I should have gotten the "Gen I" or "Gen II". I have attached pictures of the capacitor I received and of my XO.
Post edited by drselect on
Gen II are only available in small values, generally for electronics."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Those caps are correct.I have the same ones.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Thanks for the reply Face and fbm211
